Question about Brother MFC-685cw InkJet Printer
Brother mfc-685cw ran out of black ink
I changed the cartridge but got an error saying no black cartridge?
I put it in & out several times but it still says the same thing
  • 3 more comments
  • thomascote Feb 06, 2009
    didn't do the trick
  • bevlippa Feb 23, 2009
    I don't use prntr very much but ink runs out. Changed the black and was ok.Now yellow out - changed it but screen says "ink empty". I turned mach. off and restarted. Still doesn't work What to do now?
  • gildabarton Apr 04, 2009
    My Brother Printer/fax MFC-685CW indicates "Ink Empty", I have changed the cartridge but the machine still reads "Ink Empty", What should I do ?
  • hesperian Apr 14, 2009
    I had problems with this on my MFC 685 CW too.  It didn't seem to know when there were cartridges in the slots or not, and the trouble is, that until it figures out a cartridge has been removed and replaced, it will not ask you if you replaced it.  And until you are able to respond that you replaced it, it will not reset the number of dots that can be printed with that cartridge and it continues to report that it is empty.  I had to send the printer back for this issue when it was still under warranty, and now this replacement printer is doing the same thing.  I am really disgusted because now it is not under warranty any longer.
  • Anonymous Mar 24, 2014
    my brother MFC-685cw will not photo copy?
I had this problem and after shaking the cartridges (all of them) and putting them back, turning the machine on and off I noticed the printer wire was under one of the feet of the machine. One of these things worked and I believe it was the cable under the machine confusing the machine..............not very technical I know but just in case,,,,,,,,,,,fingers crossed
Posted on Feb 06, 2009
I have just replaced the black cartridge of my Brother 685CW printer and fax. Prompt says 'No cartridge". tried all the solutions above to no avail. I need to use printer urgently. Please help. Moh.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Sep 27, 2010 | Brother MFC-685cw InkJet Printer
Doesn't print black ink
Have you taken the protective film/sticker off the cartridge? - so the ink can get out...
May 06, 2010 | Brother MFC-685cw InkJet Printer
I have the Brother MFC-685CW Fax Printer, I replaced the Yellow ink cartridge but it still comes up with message "Yellow No Ink" What can I do?
Hi there
You can try.
Just take them out and gave the brass connexions a good clean and put back.
All the best Pineworks
Apr 27, 2010 | Brother MFC-685cw InkJet Printer
I am unable to print black documents on my mfc-685cw printer. i changed the ink, and still unable to print. it will print in all other colors but black
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 04, 2010 | Brother MFC-685cw InkJet Printer
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Need instructions for brother mfc-685cw in cartridge refilling
This is what you need it has the 4 user manuals for MFC-685cw
http://www.brother-usa.com/manuals/default.aspx?ProductID=MFC685cw&ProductGroupID=5
If your trying to use an ink refill kit... just poke tiny hold in top and fill with syringe
May 03, 2008 | Office Equipment & Supplies
Brother MFC-685cw InkJet Printer Logo
617 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
