Question about Panasonic DMR-ES40V DVD-Video Recorder
Dvd player split screen
When my dvd player is playing, the image is in blacka and white and the screen is a double image, or split screen, side by side. In other words, the picture displayed is 2 rather than one. My Panasonic DMR-ES40V has the same problem, split screen and B&W. I noticed it after a recent power failure from an ice storm. I can't get a full screen color picture.
  • Benbill May 14, 2009
    Turned out I was able to change a setting and it now works.
    President:
  • 1,179 Answers
I had the same problem. It turned out to be my cable that went from the dvd player to the TV. I replaced with new cable & everything worked fine again. Hope this helps & please remember to rate my answer. Thanks.
Posted on Feb 06, 2009
  • Roy Lonsinger
    Roy Lonsinger May 17, 2009
    You waited 3 months to give me a terrible rating for an answer that would have corrected your problem? Thanks.
BENBILL: I HAVE THE SAME PROBLEM. WHAT WAS THE SETTING YOU CHANGED?
Posted on Jul 19, 2009
Double image with pscan in the middle of screen
have a dvd/vcr combo,double image on tv when dvd is played, vhs works fine.
Feb 19, 2010 | Samsung SV-DVD3E DVD Player/VCR
Can't get pscan split screen off dvd player, DSAY
I had the same problem... there is a switch in the back that got touched
Jan 24, 2009 | Memorex MVD2022 DVD Player
WHITE SCREEN
Our Philips PET702/37 Portable DVD player has white screen, when i press the screen appears the image. please help me. thanks
Jun 07, 2008 | Philips PET702 Portable DVD Player
I cant get my dvd to run without the pscan split screen coming help.... follwed directions in manual it didnt work HELP memorex dvd player model#mvd2022
had the split screen with pscan triangle looked for the button on the back, no button but on the remote was a button named V.MODE pressed it and everything back to normal thanks for the help
May 16, 2008 | Memorex MVD2022 DVD Player
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Split Screen Same image on left & right on Screen
press the prog scan button this should fix it
Dec 12, 2007 | GoVideo R6530 DVD Recorder
VHS play back
I am having the same split screen black and white problem. I don't think anything simple will fix this. I have looked into the unit and almost all the video processing happens on one little PC board under the DVD. I think that the capacitors on the bottom of this board are at fault, as there have been MANY noted failures of Panasonic Professional DVC decks due to these type capacitors failing.
Oct 22, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Dvd player is producing double images
Go into the units system menu and change the unit to NTSC or PAL, depending on what country you live in. Good Luck
Jun 20, 2007 | Zenith DVT412 System
Could be that some combination of the progressive scan and the line input is confusing your system. Sometimes the line doubler on the TV set causes this when recieving a 480p input. If this effect doesn't reproduce on another set, then there you have it. Try turning progressive scan off, or change between the analog(yellow) video, the component(RGB), and the S video(fat one with pins). Good luck
May 20, 2006 | Samsung SV-DVD3E DVD Player/VCR
Televison & Video Logo
694 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
