Question about Maytag MDE2706 Electric Dryer
Dryer won't start when timer button is pushed in
We have a maytag mde2706 electric dryer. we recently had water in the basement, but not enough to damage dryer (at least we didn't think so- maybe an inch of water) we unplugged dryer until water evaporated. we plugged it back in and now it wont' turn on, the timer button won't push in.
  • 979 Answers
Hopefully, the moisture in the air didn't affect the timer. You may want to put some WD 40 on it. I would check all the wiring first. I assume you reset the breakers, checked the receptacle, especially if it is near the floor. Look under the top and near the drum and check the thermal overload.
Posted on Feb 06, 2009
The dryer is not getting hot to dry the close, but there was something on the water heater pushing on a red button
unless I'n missing something the water heater has nothing to do with your dryer. If you have an electric dryer and the tumbler is turning then you have electricity to the dryer. If however the tumbler is not turning check the wall plugin. It probably is a CFI plug and may need to be reset.
Dec 21, 2014 | Maytag Clothes Dryer Almond Timer Knob...
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
Recently had 8" of water in basement. When dryer
You may need to call for service...what your describing sounds like the motor is bad..give it several days and see if it does start but i suspect the motor is bad
GENE
Sep 10, 2011 | Roper RGX4634KQ Gas Dryer
Hot cord
change the outlet
Jul 01, 2010 | Maytag MDE2706 Electric Dryer
WONT HEAT
This is a simple dryer to diagnose.2d23ddb.jpg The limits and heater or mounted in the lower left corner of the rear bulkhead. Unplug the dryer and remove the front panel.1d97909.jpg Remove the 2 screws holding the element and get it out. (only two wires to take loose) Get it out9f0a336.jpg and check it for continuity between them two connections or simply examine the heater for breaks. If all of that is ok The cycling thermostat might be whack. If all of that is good and you have 240 volts at the receptacle then the timer may have a burnt contact inside 2261b68.jpg
May 20, 2010 | Maytag MDE2706 Electric Dryer
Maytag Dryer won't start withouth me turning the drum.
Good day. Ugly problem.
My first choice would have been the motor, but.......
Here is the process, it might help you.
The power to the motor goes first to and thru the door switch. It then returns to the timer.
When the timer is turned to any running position, power leaves the timer where it is split into 2 leads.
One of the power leads goes directly to the centrifugal switch Which is the switch on the motor with all the wires. If you spin the drum, you also spin the motor, and if spun fast enough will close the contacts on the cetrifugal switch, thus sending power to the motor, allowing it to run. I guess you have done that.
The second lead out of the timer goes to the push to start switch, it then leaves and goes to the centrifugal switch but on the power side, so it is directly connected to the main winding in the motor.
That is why when you press the press to start switch, the motor runs, and if held in it will continue to run.
In fact, at this point, the motor had 2 sources of power, either of which can run the motor.
Thus releasing the push to start switch doesn't matter, since it runs off the other source.
Possibilities.
The centrifugal switch is not wired right. Please recheck. (or the motor was bad out of the box. Happens).
The push to start switch is bad, and needs replaced.
Or, the wiring going to or leaving the push to start switch has broken or making a bad connection.
Lastley, I said the power comes out of the timer and splits into 2 circuits. Not always true, in some models the timer sends 2 seperate wires out carrying the power, with the possibility the timer could be bad.
Hope this helps.
and thank for using FixYa
Jan 07, 2010 | Maytag MDE6000 Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Dec 09, 2008 | Kenmore 62602 Electric Dryer
Batch complete sounds when start button is pushed
door switch or timmer or the knob on the timer may not be turning the timer
Nov 27, 2008 | Maytag PYE2300AY Electric Dryer
Maytag MDE2706 Electric Dryer Logo
108 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
