Question about Toshiba RD-XS52 DVD Recorder
Recording problems with Toshiba RD-XS52SU
I would have the recorder setup to tape a tv show. It will start taping but after some time, 15 mins, 45 mins, the unit will beep and the recording will stop. It does this if I just press record or if I have the timer setup. Also it sounds like a grinding noise coming from the HDD when recording. Everything else with the unit runs fine.
If the Hard drive needs to be replaced how much does something like that go for? Just a general price so I know what I am in for.
Thanks and take care
SOURCE: Toshiba DVD recorder problem
Generally, this problem is caused by bad sectors or other problems on the hard drive and can be resolved by going into the setup menu and re-formatting the hard drive. Of course, all recordings on the hard drive will be erased, so spin them off to dvd first. Be sure to have unplugged and replugged the unit immediately prior to going into the setup menu (don't try to record anything). If this doesn't work, no-one will repair this unit locally, as it must be returned to Toshiba's(TACP) depot for repair. Best of luck.
Posted on May 15, 2007
  • 979 Answers
SOURCE: toshiba 13 inch tv/vcr quits recording audio
Does the audio "cutout" suddenly, or does it ''drift" off and on?...accordianman
Posted on Feb 29, 2008
maklean
  • 1665 Answers
SOURCE: I have a Toshiba RD-XS52SU
Hi have a look at your service manual for troubleshooting
http://www7.toshiba.com/secured/tass/technical/dvd/RDXS52SVM.pdf
Posted on May 24, 2008
SOURCE: Daewoo DF4501PN
DF-4501PN/DF-4700PN
is there a hack code for dvd recorder/ vcr combi to convert it to a region free player
Posted on Jul 18, 2008
  • 6 Answers
SOURCE: recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Posted on Jan 27, 2009
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
Dec 26, 2010 | Sony SLV-678HF VHS VCR
Black and white on my tapes
Is the vcr sitting directly on top of, or underneath the TV? If so, this could be causing magnetic/static interference, and that's not good. It's good practice not to have anything that uses tape near speakers or TV's. Hope this helps.
Another possibility is the signal you are recording is coming from a cable box/digital cable box/satellite cable box. Try recording using the RCA cable inputs and outputs, instead of 75 Ohm cable, if applicable.
Apr 25, 2010 | Toshiba M685 VHS VCR
Just got this Toshiba DVR620KU and need to record from home movie VHS to DVD. Have DVD-R, I have set the time, have it on the program VHS to DVD, I start the VHS, put it on pause. Go DVD, select rec...
Good one!
Sounds like you are doing everything right. Only things I can think of are:
- Make sure the disc is a blank one.
- Try a different disc.
- Make sure the tape you are trying to dub is not encoded with Macrovision copyguarding. If it is a home-made recording then you are OK, but a factory recording on a store bought tape may cause some difficulties.
If you are still having troubles try a complete 15 minute reset by unplugging from the power source.
Apr 22, 2010 | Toshiba DVR620 DVD Recorder/VCR
I have a Zenith DVD/VCR and I am recording a tape
unless the security camera has a setting for recording the date stamp you probably can't. The camera probably has a setup tab to enable embedding the date stamp on the video.
Nov 14, 2009 | Zenith XBS448 System
Daewoo DF4501PN
DF-4501PN/DF-4700PN
Mar 14, 2008 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
Toshiba 13 inch tv/vcr quits recording audio
Feb 28, 2008 | Toshiba MV13L3 13 in. TV/VCR Combo
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Audio dropout
take it or ship it to video tech service. they will clear it and go from there. it may need some tension adustments in addition. The guy there is super cool.
Aug 18, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Open Questions:
Toshiba RD-XS55-S-TU corruption of video after firmware update This recorder is around 2 years old and was functioning fine. Occasionally I'd have a problem with corrupt pixels when copying from DVD-RAM to the HDD (never from DVD-R for some reason). I complained several times to Toshiba and they claimed since I am in Japan it is due to the Hz issue (50 Hz versus 60 Hz). I do use a transformer to provide 120 volts. However pulling the plug for 3+ minutes usually solves the problem. I upgraded to the latest firmware hoping it would solve these issues. At the termination of the update, the last couple of steps of the instructions did not occur (similar to another poster complaining of this problem). I pressed the standby switch for 10+ seconds but I did not get a 'Wait' message nor did the tray close automatically. I had to pull the plug to gain access to the recorder. The recorder starts up fine, except I have a chronic problem with corrupt pixels now whenever I dub from DVD-RAM to HDD. I have tried pulling the plug for hours and as long as a day, but no help. I also have problems with the recorder locking up during scheduled recordings: I turn on the TV and the image is locked in mid recording and none of the buttons on the recorder works to turn it off so I have to pull the plug. Of course I lose the recording and all scheduled recordings after that. Sometimes the audio would just plain fail. Toshiba wants me to send the unit in for repair at a cost of $150 but freight by U.S. Postal Service from my FPO AP address to the U.S. will run $40! I told them why should I pay for repair when it was caused by their firmware update??? I notice they have subsequently pulled the firmware file from their site, no doubt due to my complaints. Any suggestions on how to fix the recorder and/or get Toshiba to repair it at no charge, which I feel is a fair demand? I have already tried to format the HDD several times (using the Toshiba instructions via the recorder) and tried the firmware update again 3X to no avail. I even tried to use the Canadian firmware update for this unit but the recorder won't recognize it.
Feb 27, 2017 | Toshiba RD-XS52 DVD Recorder
Toshiba RD-XS52 DVD Recorder Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
