Question about Apple iPod nano 2nd Generation MP3 Player
Non stop clicking
I turn my ipod on like normal, and every time i go to even touch the click wheel it makes the noise it does when you are scrolling through songs, even though I'm not. Even when it's on and i'm not touching the wheel, it clicks. The only time it doesn't is when i lock it with the hold button. I've tried to restore it, reinstall itunes, updates, everything. Please help me quick! I need to fix it before a 6 hour car ride on Saturday!
  • 342 Answers
You need a new Ipod. Or to send your currently damaged ipod into apple to be repaired. You have a hard ware issue with the turn wheel. I figure you have probably already figured this out but i'd tell you any ways.
Posted on Apr 20, 2009
I hear a clicking noise when i plug in my ipod with click wheel
this is a relitivly common problem with ipods. this is the ipod failing. it is somtimes called 'the click of death'
if you would like to see what is going on inside:
http://www.youtube.com/watch?v=h8S5F2Bd7uA
in other words, your hard-drive, the thing that holds all the data, is broken. the hard drive itself can not be fixed, but you can replace the hard-drive.
this is problem a hardware, rather than software issue (e.g. physical damage) so its not something that can be fixed with a iPod 'restore'.
you have some choices at this point:
1) try and fix it yourself. this can be difficult but alot cheaper (if your good with directions, pick this)
go to ifixit.com
they have both the parts for the repair, as well as the instructions on how to do the repair itself.
2) send it off to apple to fix
this will be very expensive and slow, i don't recommend this.
3) sell it, and buy a new iPod.
May 27, 2009 | Apple iPod nano
Remove security code
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 20, 2007 | Apple iPod nano
Apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Apr 03, 2008 | Apple iPod nano
I connect Ipod to computer it will not sync
Try resetting the iPod, this usually works.
As follows:
http://www.pchelpforanyone.blogspot.com/
Mar 10, 2008 | Apple iPod nano
Ipod 2gb hanged
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)ipodg1-2.gif ipodg3.gif
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 19, 2007 | Apple iPod MA446LL/A MP3 Player
I-Pod wheel broken?
  • iPod classic
  • iPod nano
  • iPod mini
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
Sync problem
Sep 07, 2007 | Apple iPod nano
Frozen ipod
Aug 02, 2007 | Apple iPod nano
How can I identify which iPod model do I have?
"This document will help you determine the model of iPod you have as well as the latest version of iPod software available for your model. To ensure that your Mac or PC is compatible, check the system requirements for your particular iPod. You can always download the latest iPod software at http://www.apple.com/ipod/download/. You can tell which iPod model you have by checking: If it has a scroll wheel, a touch wheel, or a Click Wheel. The size of its hard drive. The dock connector. Icon Model Year-Month introduced Scrolling device Drive size Current iPod Software Version iPod nano (4 GB) 2005-09 Click Wheel 4 GB 1.0 iPod nano (2 GB) 2005-09 Click Wheel 2 GB 1.0 "
Sep 28, 2005 | Apple iPod nano
Apple iPod nano 2nd Generation MP3 Player Logo
93 people viewed this question
Top Apple Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
mac colar
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
