Question about Lexmark X1150 All-In-One InkJet Printer
Power button flashes, the printer will not print.
All of a sudden the printer has lost communication with my computer and the power button flashes. I can shut it off - but when I press the power button again it still flashes. The scanner works and the copy button makes a noise like it is scanning to memory but then just sits there rather than print. I've tried everything I can think of - unplug, disconnect every connection, take cartridges out and replace them (not with new because I know they are basically new and they printed fine less than 24 hours before this happened), tried to have the printer communicate with the PC in many different ways. Still no printing and power button flashes.......Any suggestions?
  • saxtoncc Feb 06, 2009
    Sorry all - My printer is a Lexmark - All in One X1150 and the power light is still flashing !
    Yes I know it's old and I can afford a better one it's just that it has always worked so good and I love it so when all of a sudden the light flashes I wonder why. If it is something simple then I can do it and still have the all-in-one I love. Even now I have another printer but since the Lexmark still scans good I will keep it, and use it for that and print with the other Hp I just connected. And thanks for the suggestion of the manual I did look up the problem there too using the same KEYwords and found nothing referring to the power light at all. Kinda dumb huh? Anyway, thanks for trying to help - I just thought someone out there might have known of the same problem.
Yes solved it - clean the ink cartridge sensors on the right of the printer where the ink cartridge go to be parked - they do a test before printing and they can get caked with ink from previous testing and thus it will most like be the black one has a problem since it does the most printing - you will need get the ink cartriges move to the center - then put hand inside the printer till you reach the right back corner - go below ink cartridge carriage rail and touch the bottom - you should feel the sensor pads there and they move a little bit even wobble some - rub the tip of your fingers over them and bring your hand out if there is a lot of black ink on your finger - clean it - i used just common ordinary facial tissue - a cue tip with rubbing alcohol might need to be used if its really dried and caked on - these sensors can go completly out and need to be replaced
- most of the time they just need cleaning
fix 2 - while you are there go ahead and remove the black cartridge and clean the tip as well
fix 3 some times the contacts need cleaning - they can get ink on them or they can corrode up as well from electrolyses - you probably need tv tuner cleaner you buy from radio shack or what ever a computer tech would recommend
after you do all of that make sure you do a print head alignment check and test - that will ensure every thing is in good working order and no more cleaning is required
most likely it is the ink sensors - fixed my brothers this morning
if you need to know more - email - davidtott@hotmail.com
Posted on Feb 20, 2010
I had the same problem. The power button was flashing and the scanner works good.
I had to open the printer and found that inside a spring was broken. The spring operates a lever wich send a signal.
If you like to know how to open the printer let me know.
Kind regards
René
zufang@xs4all.nl
Ps. Sorry for my bad english writing
Posted on Feb 14, 2009
  • 3 Answers
I have found out that if I give everything a good clean (dust gathers...! ;-( ) then turn the PC off, leave a few minutes then turn on again , it often solves loads of various problems !
Hope that does the trick...
Posted on May 08, 2009
  • 13 Answers
It would help if you mention what type & model printer it is.
Posted on Feb 06, 2009
  • Stephen Clouthier
    Stephen Clouthier Feb 06, 2009
    I feel bad. I have researched his issue for over an hour. There is nothing out there regarding flashing light sequences or light error codes for this printer. I have downloaded the manuals from http://www.lexmark.com/publications/pdfs... which is the same family & there is absolutely nothing useful. It also seems this unit is very old (2004 date range) I know we are not all rich but maybe see about a better unit now that technology us better. I suggest before doing so tho you look at the manuals for helpfulness on troubleshooting guides. Sorry again.
  • 46 Answers
SOURCE: scanner error
if you put the installation cd in the drive and then if it autostarts close it down, then go to device manager and the properties of the scanner and update driver let pc search automatically and it should reinstall it and then all should be fine i hope , had the same problem on my all in one device
Posted on Sep 24, 2007
SOURCE: error 21550 pixma mp160
I found a solution for this problem
change your usb cable.
you must use a Anti noise usb cable
it's only solution
Posted on Nov 19, 2007
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
I had the same problem with a new Canon MP970. Printed ok, but couldn't communicate with the scanner - error 2,155,0.
Canon phone support didn't help, and suggested it was a firewall problem. I uninstalled, and re-installed, turning off firewall, virus software, and everything. No luck. Tried several USB cables, no luck.
Then I uninstalled again - as well as a couple of old drivers and software associated with two now deceased printer/scanners.
This time I plugged the (same) USB in and turned on the device, using Windows' own hardware install wizard.
Now it works fine (at least for now... touch wood).
So - the problem might be either conflict with other printer/scanner devices installed, or with Canon's installation software.
Posted on Aug 02, 2008
  • 7 Answers
SOURCE: Scanner won't communicate with computer
Try this,
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
Right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready toi use, re-connect the scanner USB lead.
Windows should re-install the drivers and tell you the scanner is ready to use................hopefully!
Posted on Mar 28, 2009
  • 1684 Answers
SOURCE: HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
Printer will not communicate with the computer
1. Walk over to the printer and print a test page directly. The procedure for printing a test page will vary from model to model, so you may need to consult the user guide that came with your printer. For most network printers, you can print a test page by navigating the "Information" menu on the control panel and choosing "Print Configuration" from the menu. For many desktop printers, you can print a test page by holding the power button until the page begins to print. If you can print a test page from the printer, but not from the computer, you know there is a communication problem between the printer and the PC.
2. Remove the printer cable from the back of your printer and the back of your computer. After the cable has been removed, carefully put the cable back into place, making sure that the printer cable is tight. If your printer uses a parallel cable, be sure that it is fully seated on the back of the printer and on the computer. If you are using a USB cable for your printer, be sure that the tab is fully seated in the computer, and that the square end of the cable is firmly connected to the printer.
3. Power down the printer, the restart your computer. Click on the "Start" button and choose "Control Panel" from the menu. Double-click the "Printers and Faxes" icon, locate your printer, right-click on it and choose "Properties" from the menu. Click on the "Print Test Page" button to send a test page to your printer.
4. Look at the network card on your network printer to see if there is good communication between the printer and the network. You should see a flashing green light on the network card. If there is no light--or if the light is amber or red--the communication is not happening. To test the network communication, remove the network cable from both the network cable and the network port on the wall, then reseat the cable and check the communication again. If the problem remains, you will need to remove and replace the printer's network card.
Aug 10, 2012 | Lexmark X4650 InkJet Printer
I seem to have lost communication with my printer. It will not print. The ppwer button keeps flashing on and off. I have followed all of the troubleshooting guide suggestions. I have checked all cables,...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
Yellow light flashing saying replace cartridge that is flashing when I replace it the yellow light is still flashing
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Install the print head and ink tanks correctly iP4500
Reseat the Print Head and ink tanks iP4500
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Jan 17, 2011 | Canon Pixma iP4500 InkJet Printer
I have a Canon Pixma MX860. I have it set up to recieve communication via wireless. I has been working great. but all of a suddon when I go to print off my Mac Laptop, it pauses the printer and doesn't...
Cycle the power
If your printer was previously printing via wireless communication but can no longer do so, it may be necessary to cycle the power on the printer and Router / Access Point to restore communication. Before doing this, verify that the computer can communicate with the Router / Access Point.
On the printer, press the On button to power off the printer. Wait about 10 seconds, then press the On button to power the printer back on.
On the Router / Access Point, if there is a power button, press it to turn off the device, then press it again to re-power after waiting for about 10 seconds.* If there is no power button, you may have to disconnect the power cord / AC adapter. Check with the device's user manual.
* Wireless communication of all devices on the wireless network will be lost while you do this.
Oct 26, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
My printer hp laserjet 5l is printing in number and alphabatic what i do .
This is caused by one of two things. First be sure you have the correct printer driver installed, if you have printed to this printer before on this computer then you should be ok here. The other thing would be that the printer lost communications with the computer and when it reconnected the control codes had been lost. To check this, first power off the computer and the printer. Now check the connections between the two, the computer connection should be screwed tight and the printer connection needs to have both clips fastened. Now power up the computer and printer, try a test print, if it prints then you should be good. If you still get the odd print then replace your printer cable, be sure to get one that is rated IEEE1284. This rating insures proper bidirectional communications between the printer and the computer.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | HP LaserJet 5L Printer
The red light is on and I know it was flashing so I knew I had to change the cartridge. I delayed that day and when I wanted to print something today it indicated that there was no communication between...
Delete the printer icon. Power down your computer. Disconnect your printer cable. Power the computer on. After you log into the system, reconnect your printer cable. If the printer is found, install the driver. If not found, your printer cable may be faulty or problem with printer if you cannot print a test page.
Hope this helps.
Aug 10, 2009 | Epson Stylus Color 740 InkJet Printer
Flashing red "check ink" lights and nothing is wrong with ink
Is there a resume button on the printer? If so press this, often printers will allow you to bypass a low ink message and print for a while longer.
Jun 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
Lexmark 1200 Series
unplug your usb cable,uninstall printer then reinstall
Nov 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer cannot communicate with the computer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Sep 10, 2008 | Lexmark Z735 InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
2,251 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
