Question about Mitsubishi WS-55807 TV
Advent Color TV
One day the TV stopped turning on. We discovered that if we press power, about 2 min later it turns on but there is no sound or picture. Any ideas?
  • 25 Answers
THE CHEAPEST IS YOU NEED A COUPLE CAPISTORS ,CHECK YOUR FUSES.hAS THE SET GOT WET?.,IF SO LET IT DRY OUT FOR A WEEK AND TRY AGAIN FUSES,CAPS,POWER TRANSISTORS,THEN TRANSFORMERS ,THEN A NEW SET.
Posted on Feb 06, 2009
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
My canon mx700 has stopped printing in color
Check the color cartridge to ensure there is is still color ink inside it, remove the color cartridge, shake it and fix it back, now try print, if did not still print color, i will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see problem.
Jul 01, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Nov 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sentry RMC-10 remote can't 'discover' my tv's code
.there are several codes. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
CODES:1171,0116,0167,0176,0922
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Sentry SE-RMC10 Remote Control
Lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Jul 06, 2009 | LG 47LC7DF 47 in. LCD HDTV
Have to push power repeatedly to get TV to turn on, b&w picture
the CRT is obviously very old and discontinued ,I would recomend investing in a new set
Jun 11, 2009 | Televison & Video
When my tv is on for about 15 mins the borders turn green. I have changed the hdmi cable and it hasn't fixed the problem. My tv is a 47" vizio 1080 and it's only 4 or 5 months old. can you help?
something is wrong call vizio i bought the same tv two days later all of the color on the screen that should be black is green called repairman who came tv was working and after he replaced the mother board and daughter board tv was black turned on but no pic he tried again and i heard the arching sound he zapped it i was told by repair we need to order the power board it willl be another 3 to 5 days
i called vizio the minute that he left i was so pissed and that is not like me they are sending a new tv that was thursday i still have to wait 7 to 10 days but they are standing behind there tv i will give them that
Jun 04, 2009 | Vizio SV470XVT 47 in. LCD TV
Dead screen
this would be due to a convergence issue either in the color wheel or the ballast. It is probably a balast that will need to be replaced.
Mar 31, 2009 | LG Televison & Video
Advent Flat Screen with TV/AV Button Clicking & Lighting Intermittenly NO PICTURE
The fact that its clicking on and off tells me that theres probably a short in the horizontal sweep/output circuit of the set. You see when the set starts up the power supply detects a large current surge and shuts down. Some sets will try three times if this happens and then stop till the power is pressed again. It sounds like this set dosent have that way of operation. Its going to need a technician to look and troubleshoot the problem Good Luck
Jul 23, 2006 | Recoton Advent Advent Q2035A 20" TV
Mitsubishi WS-55807 TV Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
