Question about Kenmore 63942 Dryer
Kenmore series 90 dryer kicks breaker often. Draws 20.9 amps
What is the expected amps draw of the heating element. Fan only drawing 2.5 amps
  • gstangl Feb 07, 2009
    Thanks a lot for the info. I have a double 20 breaker. Does this mean that each breaker should have 11 amps of current or 22?
  • Kenmore Master
  • 8,220 Answers
Well do the math.... 5000 watts divided by 220 volts =
22 amps
Posted on Feb 06, 2009
  • Dan Webster
    Dan Webster Feb 07, 2009
    30 amp breaker is the norm for an electric dryer.
Have a kenmore elite dryer model 110.C8772. It draws 29 amps on one side and 23 amps on the other. That is high. What should it be or where do I find this info out
the typical dryer has a 4800 w 240 volt heating element so lets take 4800 divide by 240 = 20 so the power should be 20 amps typical. The dryer has a 120 volt motor, only the element works off 240. Check your dryer heating element to see it it may be shorted to the chassis is what I would do.
Jun 28, 2017 | Kenmore Dryers
I have a feh-015 that is in a small home with 5 registers, came from factory this way and way oversized can I run heat on first stage only?
15 kw is actually 3 stage/3 elements. Yes this would be possible depending on how handy you are. If you were to inspect your heater all 3 elements have limit switches that would turn the element off if it got too hot. Identified by a temperature rating written on the switches. Unhook one side of two of these and be sure to wrap the wire well with electrical tape. BE SURE POWER IS OFF BEFORE OPENING CABINET!!! Once complete you can always verify your amp draws each element typically draws 20 amps. Be sure your checking each line voltage. Likely have 2 breakers for a 15 kw heater, 60&30. Good luck
Feb 23, 2017 | Heating & Cooling
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
We have had issues with our dryers circuit breaker kicking off and getting heated. About 8 months ago we had a power surge in our home and it messed up a number of appliances but we thought the dryer was...
The two items in a dryer that draws the most amperage is the motor and the heater element. Since the heat element normally either opens or is okay, it is doubtful that is the problem. Unless one of the insulators is damaged and shorting to the base.
But before you start replacing things, suggest you use a clamp on amp meter and see if the dryer is drawing more current than what the breaker is rated at. If it is then the dryer has the problem, if it isn't the problem is in the circuit breaker box.
Aug 16, 2011 | Amana NDE2330AY Electric Dryer
I have a Rheem Model # 82V52-2 and its being supplied by 25 amp breakers. They do not trip out but the 100 amp main gets real hot and trips out and I believe it happens when the water heater is in use- any...
The Rheem water heater uses 4500 Watt elements
Check label on side of any appliance to see electrical rating details
2 element tank with two 4500 watt elements is still a 4500 watt appliance since both elements are never ON at same time.
Volts x amps = watts
amps = watts divided by volts
amps = 4500 divided by 240Volts or 220Volts
amps = 18.75
Your water heater uses 18.75 amps to 20.45 amps
Your 25 amp breaker should only carry 80% of rated value
25 amps x 80% = 20 amps.
So your water heater breaker is correctly sized.
You should have a 10 gauge wire going to this water heater.
12 gauge wire is a bit undersized for 4500 Watt water heater
Feel the water heater wire to see if it is warm.
If the main breaker is getting hot when 20 additional amps are being used by the water heater.
1) The house is using more amps than your 100 amp main can carry
Using the formula, 100 amps x 80% = 80 amps for the main breaker
Add up your total amp draw.
For example if your 3500 watt oven is ON, it draws 16 amps.
If your 5000 Watt electric heater is on, it draws 23 amps.
Your 1500 Watt 120V microwave draws 12.5 amps.
Add these numbers up plus your water heater, and it comes to 71 amps.
71 amps is getting close to the max 80 amp, but it's not over.
Now if you have a pool pump and and hot tub and a table saw going, the main breaker could be overdrawn.
2) To solve the problem short-term, you can put a timer on the water heater and use it only when needed.
http://waterheatertimer.org/Compare-13-electric-water-heater-timers.html
3) The main breaker is bad and needs to be replaced.
If you need help figuring circuits or timers, add a comment and I will help
Nov 05, 2010 | Rheem Water Heaters
Purchased "Reliance Lowboy electric water heater"
The water heater has two 4500 watt elements.
However both elements are not turned-ON at same time
So the water heater is 4500 Watts
Volts x Amps = watts
Amps =watts divided by volts
Amps = 4500 Watts divided by 240 Volts
Amps= 18.75
So that says a 20 amp breaker ... except for the 80% rule
80% rules says for safety, your Amp rating should be multiplied by 80%
20 amp breaker X 80% = 16 amps
20 amp breaker is actually safe for just 16 amps, and your water heater draws 18.75 amps.
The calculation shows you need a 30 Amp breaker.
30 Amp breaker requires 10 gauge wire.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Nov 02, 2010 | RELIANCE ELECTRIC WATER HEATER
Heating element drawing lots of power, big bill power
Well a dryer heating element does draw quite a bit of amps(that is why it is 220) but it cycles on and off & it is not an appliance that is used everyday. The first think I would do is read the electric meter and verify that it was not misread before condeming the dryer. If the electric meter reads are correct then it is possible it could be the dryer heating element shorting. How much do you actually use the dryer? Is the heating in your house electric and have you been using it? You could also have your electric company test the meter. Look at your usage of electricity for last year at the same time(it will be on the bill) and see what the number was.
Oct 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
I have a Amana Electric Dryer NED5500TQ. When I
It is possible that you could have a bad breaker in the panel. They will start to trip randomly when they are going bad. If not the dryer is drawing too many amps and the breaker is doing it's job. If the heating element is defective and drawing extra juice that could trip the breaker. Usually replacement breakers are not too expensive if you electrical panel is less then 20 years old and can be purchased at most home improvement stores. I would try replacing the breaker before you try repairing the dryer. If you install a new breaker and the problem continues to happen then you should check the dryer heating element. That component is what draws the most amps and would be the most common one for tripping the breaker.
Sep 25, 2009 | Amana NED5500TQ Electric Dryer
My a/c will run and cool great but keeps kicking the 20 amp circuit breaker even when no other appliance is running.
A 20 amp circuit breaker should be sufficient enough to do the job unless the breaker itself is too old, or if the connection screws on the breaker are not tight enough.
Jul 25, 2009 | Dometic Rooftop RV Air Conditioner
Motor draws current, won't turn drum.
The motor has failed & needs to be replaced
May 05, 2009 | Kenmore Dryers
Kenmore 63942 Dryer Logo
103 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
