Question about Amana NED7200TW Electric Dryer
Runs but will not heat up
Amana NED7200 WT runs but will not heat up (1year old)
    Genius:
  • 2,920 Answers
Check the heating element and the limit switches
Posted on Feb 06, 2009
I have the part to replace broken heat element on Amana 6100; where are the screws holding it in place?
Replace Amana NED7200TW Heating Element Heater Coil ...
? 10:43
https://www.youtube.com/watch?v=5469BpQpJZQ
Dec 14, 2014 - Uploaded by Mike Griswold
How to replace the heating element on your Amana NED7200TW Dryer. ... Pulled apart my dryer and ...
Oct 31, 2015 | Amana Kitchen Ranges
Dryer does not heat
Check the heater element then the thermal fuses for continuity
Dec 29, 2012 | Amana 7.1 cu. ft. Electric Dryer - NED7200
Amana ned7200 heater element changed out, now runs rough
Sounds like one of the rollers is not lining up. I would get the tech back out there.
Nov 21, 2012 | Amana 7.1 cu. ft. Electric Dryer - NED7200
Hi my dryer is only just over 1 year old so of course warrenty is up and it wont heat. it runs and circulates but no heat, my husband cleaned out the vent tube what else can we do?? it cant be major its...
it could be the heating element even though it is just over a year old, i have seen heating elements go out on 3 month old dryers, it also could be a thermostat the best thing to do is make sure it is getting the full 220 volts going to it, if it only has 110 volts the motor will run and have no heat and vise versa, then if that is good get to the heating element and look it over real good most of the time the heating coil will be broke into it wont look burnt just broke
May 04, 2011 | Amana Dryers
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana Electric Dryer runs but does not heat up - model ndw2330ayw -
I HAVE AN AMANA DRYER MODEL LE8217W2 ITWILL COME ON FOR A SHORT TIME AND THEN CUT OFF. I CHANGE THE BELT, THE MOTOR AND THE THERMOSTAT. THE DRYER STAYS ON , BUT WILL NOT HEAT UP. WHAT'S NEXT ???? PLEASE HELP!
Nov 05, 2007 | Amana NDE2330AY Electric Dryer
Amana NED7200TW Electric Dryer Logo
499 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you an Amana Dryer Expert? Answer questions, earn points and help others
