Question about Dell W4201C 42 in. Plasma HDTV
Dell W4201 Plasma Television with black screen
Problem started with Rippling lines which kinda looked like cable supplier problems. Slowly got worse and worse and then one day just Dell Logo on startup and fade to Black screen. Now I don't even get the Dell logo unless I do a Hard start. One other interesting note, DVD's and Video game consoles work fine.
I'm in Canada with no warranty left on the televison. No repair centre in my area will even touch a Dell television. I'm wondering, from all that I have read, could it be a faulty power supply and if so where can I get one?
Desperate, and not willing to toss $3000.00 out to the curb.
  • Steve Newhook Feb 08, 2009
  • kmhiservices Feb 24, 2009
    My Dell 4200 Plasma TV went black. I took it to a repair shop and they located the problem. Problem #1: Y sustain Part #LJ41-02759A Problem #2: Buffer scan bottom Part # LJ4102760A Problem #3: Buffer scan top Part# LJ41-02761A These are all original part numbers it might take a while to find them but they are out there.
    New Friend:
  • 90 Answers
Do you own the following tools:
t20 torx screwdriver
plillips screwdriver, pref. cord drill,
digital volt meter
remove back cover of tv. (MAKE SURE TV IS ELEVATED AT LEAST 3FT from ground away from carpet. Please refrain from walking on carpet during diagnostic test. turn dig meter on vdc. THE POWER BD is located on the top middle. It the biggest board on the TV. look very carefully at the board. USE PLENTY OF LIGHT. Back away from the TV for 1 minute. look to the top right, you will see a sticker with leads. Ve, Vscan, etc... located next to each one is the propoer voltage. rturn to the power board. the is a contact next to the specified lead. look for that lead, and take the voltage . repeat process 3 times, from there, get back to me. anything not registering properly, will identify problem with TV.
Posted on Mar 02, 2009
Mitsubshi 65 DLP with white and black vertical lines across the screen. Is it the DLP chip?
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 02, 2017 | Mitsubishi WD-65735 Television
DEll 42" plasma TV. The
do u have any wash out fetures in tv menu all white light this will stop that lite glitch i have samsung had same isse in my menus we have wash out feture that throw brite white light on screen that helps get glitch out ok cheak menus for screen burn in protection ok adjust it thx nick
Feb 11, 2008 | Dell W4200 42 in. HD-Ready Plasma...
Vertical black lines. But they are not solid. lg plasma 42pc3dv
This could be a poor connection with the LVDS cable which runs from the main video processing board to the screen, or a fault within the video processor on the main board. Worst case scenario is it could be a fault with the screen itself.
Jan 08, 2010 | LG 42PC3DV 42 in. Plasma EDTV
I have 2x2" black vertical lines on my plasma screen. Is this the end of it's life or can they be tuned out? Rod
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable near the black lines. Unplug the ribbon cable and look for black chips on the underside of it, I think they say 100 on them, you need to resolder both ends on each chip. Should fix the black line issue.
Dec 26, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
1" black vertical line in center of screen. Sony Plasma.
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Y SUS and Buffers are usual culprit.
You can get it from guy at
He has everything for Dell TVs
Jul 29, 2009 | Dell W4201C 42 in. Plasma HDTV
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
Oct 25, 2017 | Pioneer PDP-425CMX 42 in. Plasma...
Black vertical lines is there a fix My problem is with a hoizontal thin black line on my Dell 42" Plasma TV. Any suggestions for a fix? I had tried turning off and disconnecting from cable for awhile,...
I have the same problem. My repair shop says I need a new plasma screen. Dell says replacement screens are unavailable. I now have a 42" paperweight.
Jul 22, 2008 | Dell W4201C 42 in. Plasma HDTV
Thin Black lines going down my screen, sony Wega Ke-42TS2
These sets are common for bad connections on the ribbon cables connecting the screen to the drive printed circuit board. Or the drive circuit could have a bad drive scan IC. I doubt that but possible. Your going to need to call an AUTHORIZED sony repair servicer to trouble shoot this for you cause any other shop may not have a clue of this problem. Good Luck
Aug 08, 2006 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Dell W4201C 42 in. Plasma HDTV Logo
815 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
