Question about Euro-Pro EP923 Canister Steam Vacuum
Euro-Pro EP923 CANISTER STEAMER SF169E FUSES NEEDED
Hi, love this product, lent it to a friend who let the "kettle" boil dry several times and then gave it back to me burnt out.
Had an electronics friend take a look at it and I need the thermal fuse that is in it. The Sefuse (NEC) SF169E, 172 degrees, 10 amp, 250V.
I have looked on the web and this is a hard fuse to find. Anyone have any ideas?
Thanks, Barbara
  • 360 Answers
You are right, this is a very difficult part to find. I was able to find one source for a compatible thermal fuse, it is a non-stock item, will require special order of a min of 5 fuses at .81 ea plus a 10.00 handling fee and probably shipping. All the info is at this link.
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=090SPEC&MPN=SF+172+A&R=090SPEC&SEARCH=090SPEC&DESC=SF+172+A
Hope this helps.
Please take the time to rate this solution.
Thanks for using Fix Ya.
clarkco
Posted on Feb 06, 2009
My ep923 has the same problem. It does not heat up and there is no green or red light on. How do I replace the fuse? Ray
Posted on Oct 11, 2012
I have the same problem. When I locate a supplier that will send me less than the 10,000 mininum order, I'll let you know.
I have learned NOT to lend this type of devise to anyone else.....
Posted on Nov 30, 2010
When i plug it in it has no power. how do i fix this?
-Just happened...? It work before...?
If yes then try difference outlet. Still not work than
possibly bad switch. Check it out and fix it.
Good luck
mai
May 29, 2016 | Euro-Pro EP923 Canister Steam Vacuum
Won't turn on
probably a hex or star tool probably cost you more for the tools then the unit is worth.pretty much anything euro-pro is a thow away and is not designed to be fixed.
Jan 25, 2014 | Euro-Pro EP923 Canister Steam Vacuum
The Shark Steamer stopped steaming. Can I fix it
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Nov 22, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
SC505H Portable Steamer with broken hose in the handle
I also have the Shark steamer worked great for a while lots of pressure but then pressure started coming out of the insert part for the wond not sure if its the o rings that need replaces or just the wond it self can any one help me
Jun 24, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
I lost my attachments
Go here and order what you need or copy and paste this address into the search bar www.sharkvac.com/home.aspx
May 15, 2009 | Euro-Pro EP923 Canister Steam Vacuum
Euro-pro model EP923H Steam Valve
I suspect you have done something on this by now but . . . You need to pry out a plastic cap/insert in the top of the handle. Beneath it are 1-2 screws to remove. The halves will then come apart. I have mine broken down but have no idea what to do now. It is not making steam. Reply if you have any thoughts.
Keith
Apr 08, 2009 | Euro-Pro EP923 Canister Steam Vacuum
How to use euro-pro stainless steamer
The manuals link takes you there...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jan 30, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro EP923 Canister Steam Vacuum Logo
1,483 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
