Question about HP LaserJet 3700n Printer
Hp 3700 n
Printer state non hp installed three of the how do you clear this message I am using after market toners
  • 2,120 Answers
Scroll through the DIAGNOSTICS menus and disable cartridge check.
Posted on Feb 06, 2009
Dell printer 1250c , printer in Error state
The indicators provide information on the status of the printer and help you locate each problem. Following are the Indicator Status Condition and what they signify.
  • Jam Orange on A paper jam occurred.
  • Orange blinks The rear cover is open.
  • Toner Orange on The specified toner cartridge is empty or not installed when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • Orange blinks The specified toner is low when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • All toner indicators blink when the printer is in the non-Dell toner mode (Non-Dell Toner is set to On).
  • Error Orange on A fatal error occurred.
  • Orange blinks An error occurred.
  • Ready/Data Green on The printer is ready to print.
  • Green blinks The printer is processing or printing.
  • Orange on The printer is in the power saver mode.
  • Orange blinks The printer is canceling.
  • Start Green on To continue printing, press the (Start) button.
  • Cancel - To cancel the current job or clear the error, press the (Cancel) button.
For detailed information, please click on the link below for Manuals & Documents for the Dell Printer 1250C. Check Chapter 11 - Page 69 to 77.
Feb 24, 2017 | Dell Office Equipment & Supplies
What causes "toner not recognized" message?
Printers are programmed to reject non-genuine ink tanks and toner cartridges.
Some of them are also designed/programmed to stop working altogether if you fit an aftermarket product and you will have to get a new printer. Most likely you have one of those.
Never use non genuine products. You can try and pull the new genuine OEM toner cartridge out and refit it and see if the machine will reset and recognise it. If not I don't think you are going to get it printing again and you will be up for a new printer..
Follow some of the trouble shooting procedures in the user manual and if none of these work you are probably done with that printer.
Jan 04, 2016 | Goalsetter X554 54 Inch Glass Extreme In...
My HP color Laserjet CP5225DN shows message: "Used Cartridge". How can I fix this?
It is telling you that a used cartridge is installed so that you know that the toner tracking system cannot guarantee exact remaining toner indications. The used cartridge message is not generated by a non-HP cartridge, Non HP cartridge will generate a different error.
Jul 16, 2015 | HP Color LaserJet Professional CP5225dn -...
HP LJ 5500dn printer-replaced black toner crtrdg,w/OEM tnr crtrdge, recvd control error mssge 'clean fuser input',which we did according to online HP instructions, & another 'youtube'...
Hi Donna
It sounds like the machine still wants a new black toner, normally this message clean fuser input" clears whent he machine reconises a new Original non refilled cartridge being fitted, so it sounds like you have either a faulty cart or a non gen HP cart fitted like a aftermarket or refill. People often get confused that a cart they are using is OEM when in fact it is a OEM empty that has just been refilled or it isnt HP at all usally marked as "for use in HP" so please ensure we are in fact fitting real toners, if you fitted a HP one you would have to tear open the box it comes in.
If it was call I would unplug it from your pc, power it off then on, remove all your cartridges and ensure they are original HP, I'd remove the fuser and clean the discharge lamp area see HERE.
Id replace any consumable that look suss or was leaking. I test via the control panel ie menu/ information/ print supplies status. Can you get a status page out or does the error stop you?
If it still failed the first thing to do would be to replace black toner cart with another as I think your is faulty. If it is real HP then is a gaurantied item so take it back for replacement.
If a tec was their just 3 days ago it too should be covered, most companies like mine allow recall warranty on repair work on same fault if it occurs within 30 days or original call.
Here your user manual and a pic below of what it wants cleaned but mind you normally a new toner clears the message regardless, please note this error wasnt included in original machine realease it was a firmware update that added it so it may not be listed in early prints of manuals for your machine.
Let me know how you go the more info the better
Dec 10, 2011 | HP Office Equipment & Supplies
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage ( . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage ( . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
I get this message when I install a non HP toner and drum. "Non HP supply installed" and then I cant print anything
maybe a driver issue .. look for the driver of ur printer..
uninstall it.. and re-install it back on ur computer.. if this wont work.. hardware on the printer is having a problem
Feb 11, 2010 | HP LaserJet 2420 Printer
10.10.00 non hp supply installed
If you are using a re-manufactured toner cartridge, this is a common error. There is a chip inside HP manufactured toners that communicates with the printer; oftentimes, cartridge re-manufacturers use third party toner cartridges which lack the chip. You can usually clear this error by pressing the checkmark button several times; the only downside is that Econo-mode will usually not work.
Jan 22, 2010 | HP LaserJet 2430n Printer
How do i install a toner chip on my hp Cp2025
TONER CHIP on CP2025 printer:
This resource may help
Gives types of chips to use, sales in USA, and certain things to take note of.
The toner reset chip replaces the original HP ID chip and is designed to be used only on refilled HP cartridges.
It is not recommended to force toner cartridges to run on empty, as this can cause damage to both the printer and the toner cartridge.
The reset chips are dedicated to one color only, so that user can not swap toners.
As for actual physical installation, just push the new ID chip in until it clicks into place. The correctly manufactured ones should be a snug fit.
I have seen techs using a drop of contact glue behind the chip-board to secure it.
Copper pads face outwards towards matching printer pins.
See photo for polarity 'square' pad.
My printer is Samsung, not HP, so your toner cartridge may be a different shape.
Nov 07, 2009 | HP Color LaserJet 2550n printer + HP Color...
Toner low message
The only way to clear the toner low i believe is to change the toner.
Jul 15, 2008 | Brother MFC-8840D All-In-One Laser Printer
"cartridge memory error"
To identify the misbehaving cartridge just replace them one by one with another new, preferably HP cartridge. As far as why, HP makes lots of money by ?encouraging? users to buy genuine HP consumables. While HP?s cartridges are uniformly the best available they are are outrageously priced, thus the refill market. In an attempt to kill the remanufacturing market HP now embeds ?chips? in each of their LaserJet cartridges, unfortunately for HP refillers can replace them too. I?ve found several references to this error message and they are always linked it the printer discovering a remanufactured cartridge. In most of the other cases this automatically disables ?economy mode? printing but you can typically bypass the error message by hitting the enter (check) button on the printer.
Nov 28, 2006 | HP Color LaserJet 3500 Printer
HP LaserJet 3700n Printer Logo
75 people viewed this question
Ben Johnson
