Question about HP LaserJet 3600dn Printer
Hp 3600 dn
Printer says cartridges not installed when all of the are & inserted firmly
  • 300 Answers
Open the toner cover remove the toners then shine a torch where the toners push into the printer, from what a remember on the right hand side the black plastic breaks and you should find little pieces stopping the toners from seating properly in the printer. You will also see a wire contact hanging from each broken toner seat. Once you remove the broken bits of plastic and reseated your toners the printer should work as normal. HP have produced a mod for this problem but to be honest the printer should carry on working fine without it, there is nothing to worry about the dangling wires as the toners are earthed from the other side.
Posted on Feb 06, 2009
My HP color laserjet 3600 printer continue calibrating, I can't do anything.
Try unplugging the printer. Remove the cartridges. Switch the printer back on and insert the cartridges.
If that doesn't work, remove the cartridges, unplug, put the cartridges back in and plug back in.
One of those should reset. If not, there is Support, including Chat on the HP site. Nice printer!
HP Color LaserJet 3600 Printer series
Nov 18, 2015 | HP Office Equipment & Supplies
I installed a new cartridge in my HP color laserJet 3600 dn and the printer is telling me: "cartridge not engaged" I re-installed it several times and even ordered a new cartridge again to no...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using FIxya
Sep 13, 2011 | HP Office Equipment & Supplies
10.00.00 supply memory error
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on the toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Contact a local HP Authorized Service Center for further assistance.
Oct 14, 2010 | HP LaserJet 5200 Printer
10.00.00 supply memory error Unable to read cartridge data
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Sep 01, 2010 | HP LaserJet 2420 Printer
SUPLY MEMORY ERROR
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on the front right of the toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector.
10.00.00 Troubles shooting Link GOHERE
Aug 17, 2010 | HP Hewlett Packard LaserJet P3005 Printer
My hp laserjet 1210 mfp always reads supply memory error.. what is that?
Aug 04, 2010 | HP LaserJet M1522nf Multifunction Printer...
Hi my machine has a 10.00.00 supply memory erro message can you tell me what is wrong with it please
Aug 03, 2010 | HP LaserJet 5550 Printer
10.1004 SUPPLY MEMORY ERROR ON IMAGING DRUM Unable to read the supply data. Re-install the supply. If the error reappears, contact support.
Jul 03, 2010 | HP LaserJet 2840 All-In-One Printer
HP LJ p3005 dn printer will not recogonize hp print cartridge.
you may use a non genuine toner cartridge, check another working cartridge
Mar 30, 2010 | HP LaserJet P3005dn Printer
Hp 3600 dn shows install cartidges
One of the cartridges could be internally defective. There's no way to tell short of replacing them.
Feb 09, 2009 | HP LaserJet 3600dn Printer
HP LaserJet 3600dn Printer Logo
104 people viewed this question
Seeker5211
Seeker5211
