Question about Lexmark X75 All-In-One InkJet Printer
Printing not complete
Prints black and some pink and rest blank page.Cleaned nozzle already and lines are good, just colors still black and pink
  • 191 Answers
You may check your ink cartridge
1) the cartridge some color almost empty, need to change a new one or refill the match color ink. test it and go next if not fixed
2) long time less using cause some color ink chanel(holes) dryer, you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 Hr, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Posted on Feb 06, 2009
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    any help for you please send a feedback thanks
SOURCE:
Epson workforce 545 is printing & coping blank
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 18, 2013 | Office Equipment & Supplies
Brother MFC prints blank pages
Try disconnecting power completely, not just turning off. Wait a few minutes and reconnect to power
Also, your print queue may be full with failed attempts at printing. The printer becomes confused and does not know what to print next. You should be able to flush the queue at the computer, but the complete disconnect and reconnect may accomplish this
Sep 04, 2012 | Brother MFC-790CW Multifunction Printer
Lexmark z2300m....black printing suddenly started streaking. Prints first 6 lines then streaks on rest of page. Nozzle cleaning and manual cleaning didn't help.
Your best bet is to buy new ink cartridges.
Ensure that the entire assembly is cleaned thoroughly though, just to be sure. Nozzle cleaning is rarely useful.
Apr 07, 2010 | Lexmark Z2300 InkJet Printer
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Prints black and a pink pigment for some colors
Try this it may help, if the ink are dried no matter what you try clean it will not print , take hair dryer and blow the air on the walls of the cart for 2 min and then insert the cart back and check if it prints ....
Good luck....
Feb 06, 2009 | Lexmark X75 All-In-One InkJet Printer
Epson CX3650 printing gaps
Remove ink cartridges one by one and put it back in. If same thing happens, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the patterns appear, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Dec 21, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Samsung MFC-SF560 fax not printing complete page
If you have already try another image unit, you should try to make a copy or print a report. If the prints came out ok, the problem could be the telephone line. GOOD LUCK.
Nov 21, 2008 | Samsung SF-560 Plain Paper Laser Fax
Color ink not printing
Ahhrgh! Don't use windex. It contains additives that can harm the printer head.
I suggested this site in another post and it could help you.
Sep 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Problem with Canon MP730
hi, i was having the exact same problem with my printer. and i also tried reinstalling the driver. after reading your post i decided to see if the printing problem occurred when i used the other colors, and it looks like it's only a problem with the black ink. i printed out a sheet with the text in red and another in blue and they came out perfectly. but the black grid that surrounded the blue text, still looked problematic.
so... that means that the black ink is the problem. i haven't tried putting in a new cartridge. did you say that your problem occurred after you put in a new black cartridge, or did you try putting in a new black cartridge and you still had the same problem?
May 06, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Lexmark X75 All-In-One InkJet Printer Logo
156 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
