RCA D52W19 52" Rear Projection Television Logo
Posted on Feb 06, 2009
Bent image on top and bottom RCA 52" D52W23
A piece of crownmolding about 5' long fell in the back of the tv i believe it's the cause of my problem, other thing my kids play their videos games, but when i turn the tv on again the image is out off focus, i used to fix it with the auto converge feature but now is not in the menu anymore, can't find it anywhere on the menu
  • juanmanzanar Feb 06, 2009
    Hi there, thanks for your input, do you think that you can help me a little more, how can I fix this and what's the ICS and where they are located can you send me an e-mail with the instruccions please, thanks for your time I really apreciated
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
77
Points
0
Your convergency ics are dead!!!! They can be replaced buy anybody who has the right tools and no-how, I live in Surrey BC and I have fixed 5 tv"s with the same problem myself !!
  • Anonymous Feb 10, 2009
    if you can send me your email address I will send you a picture of what to look for so you know what your ics look like. Then I will be able to give you a little more help directly to you! My Email:- [email protected]
Replace a projection bulb on a RCA D52W23?
I have this tv.
pull it out and start undoing the screws towards the bottom half of the tv around the back, get the speaker grille off and then in there is your access cover for your bulbs. theres three of them red blue green. the bulb assemblies and circuit boards are integrated 3 bulbs -three separate assemblies. you will probably have to turn the tv back on when its disassembled to see which bulb went.
jm
3helpful
RCA D52W23 52 in. HDTV CRT TV when i turn it on its on for 10 second and turns back on and off for 3 times then it stays off
Thats the CP150 cp114 and CP120 issue causing that. You can get the repair kit with the same name at www.tvrepairworld.com the kit contains the capacitors and the CD with detailed instructions.
RCA HDTV D52W23- words in 3D - picture at top and bottom black
are you still having this prob? i am having a similar prob with the same brand of tv. if you had yours fixed please help me with mine.
i think it is the convergence ic. i need three ic but the distributer will nit sell no less than ten of them. if you or anyone need any of those ic i could let you some for the same unit price i bought them. posted 09/02/2009
RCA D52W23 convergence problem
If you cannot adjust it with customer menu u need professional. May need service adjustments.
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Sansui Projection TV - RCA D52W23 52 in., Problem is tv gets turn off automatically after few minutes. It doesnot off but a blue screen with lines appears immd.., it takes long time get the picture on...
CK for Bad capacitors cp114,120,150 if any of them is puffed up on top it is bad so replace all 3 cp150 is 2200uf 16v other two are 220uf 35v also resolder all pinns on FBT flyback transfomer.
52"RCA HDTV projection TV
take the back off and you will have access to the top mirror and the screen mounts. with those removed you can then clean everything...unplugged .
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
