Question about NEC Versa TXi Notebook
Can not get on the internet when i put ether cord in from dsl to toshiba A25 - S207. KEEP SAYNG i got one but i cant connect my disk to install verizon disk so i can get on the internet. can u please help me solve this problem. tell me what i need to do
  • 1 more comment
  • thedevil418 Feb 06, 2009
    is not an internal or external command operable program or batch file
  • Randall  Trahan
    Randall Trahan May 11, 2010
    What? I do not understand your situation. Could you explain it to me one more time. What exactly are your trying to do and how are you going to do it.
  • Randall  Trahan
    Ok do this first, to check and see if it is your network card causing the problem. We're going to go into DOS, click on start>run then type cmd. In the run box. Once inside DOS type ping 127.0.0.1. Let me know if packets came back or if it said zero packets. Its called a loopback test to make sure you card is working properly.
I WANT MY DRIVERS FOR LAPTOP TOSHIBA SATALITE SA10-S203 PLZ
You can download any orall the Windows device drivers for your model laptop from the Toshiba WEB sitefrom their download page. Make sure you enter the model of your laptop so youcan get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Apr 17, 2011 | Toshiba Satellite A25-S207 Notebook
I HAVE TROUBLE TO REGISTER MY TOSHIBA. MY INTERNET CONNECTION IS A HSDPA USB STICK WHICH I SUPPOSE IS NOT AN OPTION TO CONNECT
Call Toshiba Warranty department if you can't register it online. They will be happy to assist you in registering your Toshiba notebook. 1-800-2407100
Jun 05, 2010 | Toshiba Satellite A25-S207 Notebook
I need a restore disk cuz im gonna redo my laptop is there any way to get the drivers and stuff w/out a physical disk
You should be able to go to the Support section of the Toshiba website and download all of the drivers that you need.
Jul 28, 2009 | Toshiba Satellite A25-S207 Notebook
Possible mishap with the power?
Three possible reasons why this has happened
1 - The power supply cord has a faulty or broken wire somewhere and needs repairing. Take a good look and see if you notice anything out of the ordinary (UNPLUG THE POWER CABLE FROM SOCKET AND COMPUTER BEFORE ATTEMPTING TO LOOK)
2 - There could be a physical problem with the plug or socket for where it connects to your laptop and needs to repaired or replaced
3 - The computer has short circuited with the power cable socket in your laptop preventing any power for the Laptop
Hope this helps
Nov 18, 2008 | Toshiba Satellite A25-S207 Notebook
Wireless connection
on the left side is an on and off button,is it on. what is the name of your router and adapter if is used.
Oct 25, 2008 | Toshiba Satellite A25-S207 Notebook
Your laptop?
it would be easy...i think you can do that alone..if file missing only...try to repair your windows....first, what operating sytem do you have? XP or vista?....i hope you have the oroginal cd for that...if you have,then no problem.....lets start....
1.go in bios setup..change the setting into the CDrom boot.
2.insert the OS disk and save the setting in the bios and amke restart.
3.you can boot now into the OS cd and press any key to continue..and you will install now the windows....
Oct 19, 2008 | Toshiba Satellite A25-S207 Notebook
You posted about a toshiba a25 s207
ok...first, i suggest u to not wait for that copy...if u have original serial number, i suggest u to borrow anyone's cd for windows....ok, second is u have to fully format your hardisk and then install windows inside your notebook....third, as windows vista u can skip inserting cdkey.u can verify your key after u install your vista by using internet after u click properties at my computer's icon....forth and last, u can download all the driver for your notebook by clicking to this link
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
that's all....hope this will help...
Slow
Getting 330 error. In order to fix that, you can run this command at dos prompt > SFC /SCANNOW
It can fix errors at windows XP. Normally there are two memory slots for toshiba satellite. You might be running at 512 or two 256. You can purchase two 512 or i 1g.
Oct 07, 2008 | Toshiba Satellite A25-S207 Notebook
Toshiba A25-S207
That flashing light indicates that the laptop is not getting power, check and test your power cord. That light should be light solid when plugged in. good Luck
Sep 18, 2007 | Toshiba Satellite A25-S207 Notebook
NEC Versa TXi Notebook Logo
27 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
