Question about Lexmark X75 All-In-One InkJet Printer
Prints black and a pink pigment for some colors
I cleaned the nozzle and the black and pink pigments are the only colors that appear.
    Genius:
  • 2,035 Answers
Try this it may help, if the ink are dried no matter what you try clean it will not print , take hair dryer and blow the air on the walls of the cart for 2 min and then insert the cart back and check if it prints ....
Good luck....
Posted on Feb 27, 2009
Canon PIXMA MX922 won't print black text
Is it out of color ink? It will not print true black if you do not have ALL print cartridges working.
Jul 10, 2016 | Canon Office Equipment & Supplies
I haven't used my canon pixma for a few weeks, came to use it again and the 3e black cartridge won't work, (tried printing from computer and copying) have done a clean, deep clean and nozzle check, even...
The black print head is clogged. The reason why the black is clogged and not the photo black or any colors is that the black is pigment ink and the photo black and colors are dye based ink. The pigment ink is a particulate formulation that binds up when water is evaporated out of the ink. You need to buy a new print head the fix the problem. You can buy a new print head for $75 from precision roller.com.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
This Canon MP530 will print a nozzle check with no problems. It will color copy with no problem. No ink cartridge lights are on. It will not print a report or copy in black. What's wrong?
On your nozzle check, do you see the grid at the top (indicated by red arrow in picture below)? If you don't see this, your pigment black nozzles aren't working. The black bar at the bottom is from the dye black nozzles (small black tank). You may have either plugged nozzles or a bad print head.
Mar 02, 2010 | Canon PIXMA MP530 All-In-One InkJet...
No black ink printing all other colours okay
This is getting to be a very common problem that I've found almost constantly with the HP88 K/Y (Black/Yellow) printhead. The problem is that the Black ink is pigment ink and in certain environments this just clogs to the point that no amount of cleaning will actually resolve the clog and you have to replace the printhead. The only long term solution I've been able to find is to replace the black cartridge with a 3rd party dyebase ink cartridge and run this through a NEW printhead to replace the pigment ink in that. Dyebase ink does not have any of the same problems and will work perfectly. The only trade off is of course that you lose your warranty and there is a certain amount of ink "bleed" where the edges of black are more fuzzy from ink mixing while it's wet but this is fairly minimal and as the L7580 is only really a document printer (rather than a photo one) it shouldn't make a huge difference. I've used this approach to great effect both at home on an L7680, K5400 and K8600 plus on the same models in 3 different schools where this clogging issue occurred so it's tried and tested. Hope it helps.
Jun 10, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Large black ink tank is not being used by the printer.
The little cartridges are pigment for photo printing. The Large black cart is ink for plain paper (usually text) printing. If you select a photo paper in the print setup menu, you will use very little of the ink.
To check the function of the large cart print out a test sheet from the printer maintenance menu. You may need to run a head cleaning to get all the nozzles to work.
May 11, 2009 | Canon i860 InkJet Photo Printer
Poor color printing
sound like the printer need a good cleaning. including the toner opening.
The toner may be expired. as the color pigment deteriorated with age.
usual color pigment store in a dry and cool place can last 2 years, if lefted out in the printer, it may only give you max 1 year.
Nov 04, 2008 | Samsung CLP-500 Laser Printer
Black ink only
Print using pigment black ink only (Windows) Instructionsto print using only the pigment black ink tank only. Occasionally youmay need to print using black ink only. Using grayscale alone does notprovide this option and the color inks will still be used. By followingthis procedure you may print using only the pigment black ink tank. Note: Image quality may be sacrificed when printing photographs.
  1. Open the Properties / Preferences window for the printer.
    For Windows Vista
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Clickyour right mouse button on the listing for your printer, and thenselect 'Printing Preferences...' from the menu that appears.
    For Windows XP Home Edition
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click on the Main tab.
  3. Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
    Note: The pigment black ink will only be used when printing on plain paper.
  4. Select the box for 'Grayscale Printing'. If the document to be printed is in black only, then this step may be skipped.
    Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
  5. Click 'OK' to save the changes.
The printer will now only use the pigment black ink tank.
Oct 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Problem with colors in Canon i850
OK this is the tricky part. You will have to take your printhead out of the machine (the peice of plastic the cartridges sit in). It just has a single arm holding it in and nothing else. There a few things you can try I will list them in order of safest to least safe.
1. Leave the cartridges in the head (even if you have to hold them in with your hand) and use a thin head on a decent vacuum cleaner (preferably one that can handle wet and dry so you don't get ink everywhere) on the bottom of the head where the ink comes out. You may be able to suck the ink through effectively removing any blockages.
2. You can leave it to soak in Isopropyl alcohol or windex or really hot water (not boiling) and it may remove any blockages. You must make sure that it is completely dry before reinstalling it though or you will wreck the head.
3. Using a jeweller's ring cleaner sit your printhead in an inch of water and activate it for 60 seconds (This can also damage your printhead).
You can get an idea how successful you have been each time by dabbing the bottom (where the ink comes out) onto paper towel or a tissue. You should see 4 lines, black, cyan (blue), magenta (red) and yellow.
If all of this fails you may need a new printhead which is dearer then a new machine.
Good Luck.
Please rate my advice, good or bad.
Feb 07, 2008 | Canon i850 InkJet Photo Printer
Lexmark X75 All-In-One InkJet Printer Logo
150 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
