Question about Acer Aspire™ T180 PC Desktop
Acer l100 will not restart
Started using iolo system Pc tuneup. when it updates and the pc needs to restart it won't. I shut the pc off and then the pc won't start. all this started when the started pc tuneup.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Do you have your original Windows disk.
  • 73 Answers
If it's just not loading Windows, restart into Safe Mode. Instructions here:
http://www.bleepingcomputer.com/tutorials/tutorial61.html
Restore from a system restore point created before you ran the PC tuneup software. Instructions for Vista:
http://bertk.mvps.org/html/restoresysv.html
Instructions for XP:
http://techpaul.wordpress.com/2008/09/04/how-to-use-system-restore-to-fix-windows/
Posted on Feb 06, 2009
Why does Acer l100 PC shut down?
You need to service you pc ar laptop. The cpu needs to get new thermal compound every 3 to 6 month's add me on facebook Nic fourie for complete guide to how the service your own pc or laptop
May 11, 2014 | Acer Aspire L100 PC Desktop
Trying to install belkin wireless for windows 7 and its saying missing shortcut. How can i fix that?
You need iolo system mechanic(not the one with antivirus) just system mechanic from iolo.com.If this fails to fix your missing shortcut,try "tuneup utilities".You can get this at pc world or staples or office supply units.
Aug 09, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
Hi
thank you for your query
Please can you try the following
1) go to www.devicedoctor.com
2) Download and install the device doctor software
3) Once installed open it up and click scan, it will then scan your PC for the best driver
4) Download the driver (entitled VGA driver) and install
5) Restart and see if this cured the issue
Regards
Shauqat
Jun 02, 2010 | Acer Aspire L100 PC Desktop
The iolo system shield would not update
This is gonna be Lengthy process.
First
Uninstall System Mechanic Professional
Open the Control Panel by clicking:
Start>Control Panel
or
Start>Settings>Control Panel
Open Add or Remove Programs.
Locate and select the entry entitled iolo technologies System Mechanic Professional
Click the entry’s corresponding Change/Remove button.
Follow the on-screen instructions to uninstall, restarting the computer as prompted.
Remove the System Mechanic Professional registry entries
WARNING: Using the Windows Registry Editor incorrectly can cause serious problems and may result in an inoperable operating system. Use Registry Editor at your own risk and discretion.
Click the Windows Start button.
Select Run.
Type regedit in the Open field.
Click OK.
On the left-hand side, expand HKEY_CURRENT_USER by clicking the + symbol next to the entry.
Expand Software.
Expand the iolo folder.
Navigate to the System Mechanic Professional folder.
Right-click on the System Mechanic Professional folder and select Delete.
Click Yes to confirm the deletion.
On the left-hand side, expand HKEY_LOCAL_MACHINE by clicking the + symbol next to the entry.
Expand Software.
Close the Registry Editor.
Click Start>My Computer and then navigate to your Local Disk (usually the C: drive) then Program Files\iolo\System Mechanic Professional.
Remove residual antivirus files
Close all open windows and restart the computer
Follow the same process to uninstall the System Shield also.
Reboot the PC after everything is over.
Then install System Shield First, reboot the PC after the installation and check if the update it working or not. Once its confirmed that System Shield's update is working, install the System Shield.
May 30, 2010 | ACDSystems System Mechanic with Bonus Iolo...
My acer aspire l100 keeps shutting off. it sometimes will stay on for like two minutes but most of the time it shuts down after like 30 seconds. it works fine in safe mode. most of the time it shuts off...
this seems like a software issue . if you can not run your system but ift works fine in safe mode try to run a system restore from factory disks and see where that gets you,
May 14, 2010 | Acer Aspire L100 PC Desktop
I shut computer after windows updates and now it won't power up
1.Try booting into safe mode (F8 on startup) and then uninstall the update or you can run system restore. 2.try going to the advanced boot options and choose "Last known good configuration" 3.The last option is 'to do a repair install' if you have a Windows XP CD you can just do a repair of the OS.
Jul 16, 2009 | Acer Aspire L100 PC Desktop
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
Matshita DVD-RAM driver won't load on Acer Aspire L100 (Vista)
you need to repair this by using the vista installation cd just press repair the driver will be reinstalled by this oerating system
Jan 21, 2008 | Acer Aspire L100 PC Desktop
Error Message
sounds like sound drivers.
Install this update to resolve an issue where the Realtek HD Audio Control Panel may not start after you install security update KB925902 (MS07-017) and security update KB928843 (MS07-008).
http://www.microsoft.com/downloads/details.aspx?familyid=74AD4188-3131-429C-8FCB-F7B3B0FD3D86&displaylang=en
Nov 08, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
