Question about GE DBXR463EBWW Electric Dryer
Dryer doesn't shut off when set to more dry
When I use the "more dry" setting the dryer doesn't shut off. Timer moves to "less dry position"but no further, dryer heats up and dries fine and works when OK in the "timed" positions
  • 686 Answers
Moisture sensor problems
Posted on Feb 18, 2009
My dryer works on high heat on the timed side of the knob, but won't work on the low heat and high heat (more dry, less dry or energy preferred setting)
Does this mean the timer wont move or it will not dry ? if it will not dry it is more than likely the timer , if it wont advance then you have a shorted element
Nov 03, 2015 | Dryers
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Dryer control doesn't move on less dry more dry setting and will not shut off when clothes are dry.
If clothes are hot then try dryer on timed dry. If timer does not move then timer is most likely bad . Replace. If timer moves on timed dry it is not getting hot enough to click the cycling thermostat.(If clothes are overly hot above 160 then the cycling therm. is stuck Replace.
Oct 29, 2010 | Dryers
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool model LGB6000KQ1 gas dryer runs but has no heat only cool air. The timer when set to timed drying, moves down to off position, but does not shut off. Please let me know what parts may be faulty...
If the timer advances to OFF and does not stop you have a bad timer. It could also be the cause of no heat. Replace the timer first. If still no neat replace the glow bar ignitor.
Aug 24, 2009 | Whirlpool Dryers
Gas Dryer runs non-stop.
Repairing a dryer that won't shut off many seem daunting, but fixing your own appliance is actually pretty easy. The toughest part is figuring out what dryer part is the problem. We've created a list of the most common parts that can cause a dryer to not shut off. Use this list to diagnose the problem you're having and then enter your model number into the search box to find the right part for you. You'll also be able to access even more detailed repair help and tips about your dryer.https://www.youtube.com/watch?v=rXs6cL_prAQ
Mar 16, 2017 | Whirlpool Dryers
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Nov 14, 2008 | Whirlpool GGQ8831L Gas Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Auto Dry not advancing
It sounds like a timer problem since it happens during timed also. Some dryers don't have an actual moisture sensor for auto dry. They work by knowing that as long as the clothes are wet the temp won't go past a certain point. As the clothes dry it trips a thermostat that lets the timer advance. Until this is fixed DON"T trust the timer to shut off the dryer. Sometimes it won't or could leave the dryer running for hours. This has nothing whatsoever to do with fuses. There are no fuses in a dryer. Just high limit thermostats and other devices that will shut off the heat but usually not the motor.
May 30, 2008 | Kenmore 73952 Gas Dryer
GE DBXR463EBWW Electric Dryer Logo
213 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
