Question about Mitsubishi WD52527 52" Projection HDTV
WD52527 - Device button doesn't work and causes TV to reset
Beginning yesterday, each time I try to push the device (up/down) button on the TV remote the picture begins to be "jerky" and then after about 15 seconds of this the TV resets.  Once I push the device button, the remote also quits working.  I can't even turn the TV off at that point.
  • Janodude Apr 21, 2009
    I have the same problem. Device button will not work, then all stalls on the TV and when device button and menu pressed together the TV turns off. Device screen will not come on at any point. Unable to use DVD player.
    Novelist:
  • 159 Answers
There is a first step to take in the power supply. (a couple of capacitors could be dry).
The areas where this power is feed is really diverse. But as a general rule the power supply cannot be faulty if we expect all microprocessors working steady and fast.
as as second step i would think in the area related with the video processing who escalates different resolutions as you request a different source of video this requires a fastest microprocessor answer making the rot program go to this default screen when not answer is given.
As you can see this problem requires a repair level component. there is not a user's menu process to do. A visit to the work shop is needed
Posted on Apr 22, 2009
Small vibe remote from dollar general doesn't have a set button that I can see. Does anyone know where its located?
i lost the book to vibe remote ...i just went and bought another remote returned remote kept book..here it goes....hold down device tv cd vcr button till light goes on while holding dont let go wait till light goes out then hold down power button while still holding both buttond now wait for light to go out then let go of both buttons then point remote at device and push power button untill device turns off then push stop button to set and there you go all set....note you may need to push power button a bunch of times to find code so hang in there...if in doubt start over
Sep 26, 2012 | Televison & Video
I need the codes for panasonic tv for my jumbo remote
If you are referring to the Jumbo Remote, the codes can be found on the website at http://www.jumboremotecontrol.com/remote_control_code_list.html.
To program the remote, use the following steps:
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Here are the codes that they list as being potentially applicable to your television:
003,051,055,062,070,148,170,171
Jun 25, 2011 | Universal Remote Control Remote Control
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
1. Turn on the device you want to program into the remote.
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
I need code for coby tv-1360, to work with rca systemlink 4
Hello
There is no code for your Coby with RCA systemlink-4 specified. But you can find the stored coed in Coby with RCA remote. Here is the proceedings. Do it and check.
Press and Hold CODE SEARCH button until ALL FOUR device choice buttons light up.
These FOUR buttons DO light up, they are on the SECOND ROW from the top; and from LEFT to RIGHT are named:
SAT-AUX CABLE VCR TV
After ALL FOUR are lit, RELEASE the CODE SEARCH button. All four lights will stay lit!
Select the device you want to control. Press that button ONCE!
The light will stay on for the selected device, the other lights will turn off. Press the OFF-ON button repeatedly until device powers up or down. If device is off and this turns it ON, try channel up or down. If device is turned ON and this turns it OFF, press ENTER and try to turn it on.
If this does NOT work, you don't have the correct code. Go through all the previous steps from the beginning. I actually counted the number of times I depressed the OFF-ON switch, and this helped immenssely! For example, the TV turned Off or On after 19, 45, 76, 94, 115 and 164 depressions of the OFF-ON button.
Of course it wasn't until I hit the 164 mark that it controlled all functions, and is now going great! But I knew NOT to **** around with a number I had all ready tried, and which didn't do the trick the first time!
Remember, when you start from the beginning, it's just that, from the beginning! You'll notice the device turns on or off after the same amount of depressions of the OFF-ON button, but that may not be the code you need.
Again, this is for an RCA SystemLink 4 Remote Control only, NOT for any other model!!
[2]
Without codes:
  1. Turn on TV.
  2. Press and hold CODE SEARCH until all device buttons light, release button.
  3. Press TV button. TV button will stay on.
  4. Press POWER repeatedly until TV turns off.
  5. Press ENTER.
[3]
With codes:
  1. Turn on TV.
  4. Using number keypad enter code for TV.
  5. Press ENTER.
Mar 02, 2011 | Coby Televison & Video
I need the code to set up my tv using at&t uverse remote, and the tv has no power button
  • Make sure that you have turned on the tv before you begin programing your Uverse remote control.
  • Hold down the TV button on the Uverse remote. (If you are trying to program a different device, hold down the button that names that device). As you are holding the TV button, press and release the OK button. You know you have done this right when all the mode keys flash twice.
  • Find the 4 digit code for your device
  • At this point, the TV mode button should flash three times. Try to turn the TV off by pushing the power button. If it does not turn off, try a different code. The manufacturer of your TV has many codes.
  • If none of the codes for your device work, try manually searching for a code. Go back and repeat steps 1 and 2. Then enter 922. Hold play as the remote cycles through various codes. When your TV turns off, push enter.
    ---------------------------------------------- Sharp TV codes for at&t remote: 1004, 1009, 1011, 1025, 1064, 1077, 1078, 1081, 1097, 1099, 1153, 1157, 1274, 1298, 1311, 1312, 1362, 1375, 1378
    Jan 24, 2011 | Sharp 27R-S50 27" TV
    I lost my code sheet. how do i get a new one.
    Try to do this:
    Guide to Programming the Remote
    Follow these steps to program a device into your remote control. Thereare two ways to program your remote. If you already know the code foryour device, you can program it into your remote manually. If you donot know the code, you can use the code search function to program theremote control.
    Using Code Search:
    4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button toprogram the DVD player, etc. The light on the remote control willblink and stay on.
    5. Slowly press and release the power buttonrepeatedly until the device turns off. Each time you push the powerbutton the light should blink once.
    5. Enter the code for your device using the number pad. The light willblink each time you push a button. If the code works, the light willturn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work,start from the beginning by holding down code search until the lightstays on and use a new code.
    Ifyou used the code search function to program your device and want toknow the code for future reference, you can retrieve the code from theremote. To do this:
    2.Press the device button for the code you want to retrieve. Press TV toget the TV code, etc. The light will blink once and stay on.
    2. Use the number pad to enter 2 digits for how many minutes to use forthe timer (01 to 99 minutes). The light will turn off and start timing.
    SOURCE
    Sep 29, 2010 | Innovage Jumbo Remote Control
    When I push the device button on the remote, I
    I had this same exact problem with my WD-62627. I got mine to work by re-initialing the tv. I could not believe this worked. Try this, 1) turn on the TV
    2) press MENU 2,4,7,0 then ENTER
    3) the TV should INITIALIZE
    4) Press the front reset button on the front of the TV.
    5) should work again....if so.....
    6) email me at Larry1965@hotmail.com to thank me. :)
    Dec 30, 2009 | Mitsubishi WD62628 62" Projection HDTV
    When accessing the Device Menu, the TV turns off
    I would contact Mitsubishi and see if there is s software upgrade for this model. You can contact them at 1-800-332-2119.
    Hope this helps,
    Skyassoc
    Jun 28, 2009 | Mitsubishi WD52527 52" Projection HDTV
    Remote control
    buy the radio shack "6 in 1" remote. It is absoluetly amazing. picked up all my codes, and actually uses voice commands to step you thru the process. It is the only remote I could find without spending 100 bucks or more that worked for my sylvania, and at only 15 bucko's, you can't beat it.
    Dec 21, 2007 | Sylvania LC320SS8 32 in. LCD Television
    Mitsubishi WD52527 52" Projection HDTV Logo
    170 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
