Question about Pioneer AVX-P7300DVD
I need the connection diagram of the harness of dvd
Where it fence the cable of corriente+ and neutral desprendio of the harness and I am not needed the connection diagram of the harness
  • 323 Answers
How do I connect star connections?
From what you have said, I am guessing you have discovered the ground point. That "floating neutral point" is the ground and should be connected. If the cable isn't connected, it isn't as safe. In general it is precaution.
Elisa Jed '
Jun 24, 2014 | Varian Mdc High Vacuum Research Gas...
Do you have a wiring diagram for a Yamaha 1300, 2007 model. I have one plug not firing I need help!!
Hi, Anonymous and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and CDI box.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2007 FJR1300 Low speed misfire
Yamaha 1300 Tourer Yamaha 1300 Tourer Fansite
OEM parts for Yamaha
May 02, 2014 | 2007 Yamaha FJR 1300 A
Essick air compressor wiring diagram
telepathy do not work that hot as in hollywood movies...
you need to provide a model or at least if this is three phase or single phase...
single phase is easy, you have cord with three wires, earth, active and neutral.
you need to open connection box on your compressor and you will find three wires there terminating in junction box, earth connect to earth (usually green or green with yellow stripes), then you have your neutral (usually brown or black) and active (usually blue or red), connect them, do not put cover on yet, plug cable into the power point and switch on/off power. check if motor is rotating in correct direction, if fuses are not blown... if motor is rotating in wrong direction - switch power wire with neutral wire, it just meant that you wired it in reverse...
do not need diagram for that...
do not forget to give some points...
Dec 30, 2013 | Park Tool Inf1 - Shop Inflator For Use...
While driving transmission will slip into neutral
The item that is electrically controlled and it turn controls the gear shifts is the TCM. transmission control module. They are prone to playing up and one of the reasons for that is moisture in the cable connections near the box. Have some one pull all the harness connections concerning the box apart and blowing them clean with air and ensure that they are dry and clean
Dec 28, 2013 | 2004 Jeep Grand Cherokee
I need a wiring diagram for a 274A Light switch/ plug in. Everything we try, we are not getting anywhere.
There are more than a few ways to wire this device. The switch box where the device is installed _must_ have a neutral wire for the receptacle to work. This is usually a white wire.
The switch box should have at least 2 cables in it. One cable is the incoming HOT(black) and neutral(white) from the circuit breaker panel (or source). The second cable is the outgoing switch leg(black) and neutral(white) to the light. Each cable should have a bare equipment grounding wire.
The most common way to install this device is to connect the hot wire to one of the black screws, pick one. ( I'm assuming that you have _not_ removed the brass tab between the 2 black screws.)
The 2 neutral (white) wires are twisted together under a wirenut along with a pigtail which connects to the silver screw on the device.
The black wire that goes to the light (switch leg) is then connected to the brass or gold screw.
The bare ground wires are twisted together under a wirenut along with a pigtail which is connected to the green screw.
Aug 28, 2010 | Cooper Industries Cooper Wiring 274W...
Recently slid into a fence durring ice/snow storm.
I'd say the linkage is a little bit off and the shifter is not quite putting the linkage in the park position. To confirm this you might try pushing and or pulling on the shifter a little bit as you trying to start the vehicle.
Jan 03, 2010 | 2001 Ford Explorer Sport
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Pioneer AVX-P7300DVD Logo
280 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
