Question about Dell E173FP 17" LCD Monitor
Monitor display is blurry, with shadows and waves next to text
My Dell monitor has been working fine for years, and now suddenly the images and text are blurry and there is a shadow next to everything.
  • May 11, 2010
    Is this an LCD monitor like the heading says, or a CRT type? What is the actual monitor model number?
    Problem Solver:
  • 5 Answers
Jnanda,
Could be one of two related situations both have to do with built up magnetic flux:
!. If you have used the monitor for a significant amount of time and have never degaussed it that might be it.
To fix: Go to where your monitor's controls are (eg screen size/position, Brightness, Contrast, etc.). Providing that we are referring to an older style monitor (like a TV) and not a flat screen, you should find a degaussing button located there. This button is marked with a depiction of a horseshoe magnet. Press it.
If you have on screen settings control, hit the menu button and select the icon that looks like a horseshoe magnet.
You'll hear a buzz and the screen will go kooky for a moment.
You're then degaussed. Your problem should go away.
2. You may have moved the monitor close to a source of electromagnetic interference (or vice-versa) this will also cause that sort of thing you describe (remember that there are electrical lines in the walls (another source of EMI)
In that case move the monitor away from the EMI source or move the EMI source away from the monitor.
Remember that it could be both 1 and 2. So if the problem lessens but does not go away fully try both steps.
Posted on Feb 06, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
SIMPLE !! The "shadowing" you talk about is due to cables in back of your computer, touching or too close together. I had this happen to mine. I moved the cables apart, and no more shadows !! Sounds too easy, but it works. Takes a few seconds. Immediate results.
Posted on Nov 06, 2014
Picture on Monitor has shadows and is blurry and colors are mostly blue, green, purple. Print (text) is okay. Any solutions? Thanks
Did the problem occur out of nowhere? Is it a new monitor and was like that from the start? Is it an old monitor? Laptop? LCD? There isn't enough information.
However, try setting all video settings to default or "recommended". If that doesn't work, be sure your video card and display drivers are updated.
Oct 18, 2013 | KDS Computers & Internet
I have a dell xps M1210, and It has problems with the screen. I already probe and it work fine with an external monitor. You can not see the images well but there is not problem with text. I think there is...
hello, if works fine whit external monitor so is no problem whit motherboard, problem must be in display or the connector that connect motherboard to display
its not dificult to change display but i recomand that u go to a specialist
Sep 23, 2011 | Dell XPS M1210 Notebook
While working on my laptop it suddenly become blurry, the images are seems mirrored, the text become doubled and it hard to read. The graphics display was really blurry and even i open to safe mode still...
Look for a 9 pin or 15 pin plug on the side of your laptop. You can connect an external monitor to these type of jacks . If the display on the external monitor is clear then your laptop display panel is the culprit.
Jan 05, 2011 | Computers & Internet
Acer Monitor P191W - how can I remove what looks like a
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Dec 14, 2009 | Acer P191WBD LCD Monitor
How do I fix my screen from being blurry? I have an AccuSync LCD 72vw with AT&T services.
Hello: Try the following:
Signal cable should be completely attached to the computer.
Use the OSM Image Adjust controls to focus and adjust display by increasing or
decreasing the FINE control. When the display mode is changed, the OSM Image
Adjust settings may need to be readjusted.
Check the monitor and your display card with respect to compatibility
and recommended signal timings.
If your text is garbled, change the video mode to non-interlace and use 60Hz refresh rate.
Nov 19, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
Text on screen trailing to the right
Check the VGA plug and lead between the monitor and computer.
Does it get worse or better while you move the lead around?
Oct 20, 2007 | Philips 170S7FS 17" LCD Monitor
Ghosting image after 3 years of perfect operation
ghosting is a memory problem, the monitor has a memory chip this helps with the video rendering to display the image, the chip can over time become damaged like any other memory chip, its its read use delete type but some times it can take longer to delete this then gives you the ghost shadow. it can sometimes be the software glitching, but there is no way to fix the firm wear on the monitor as the chip is pre programed before the monitor is assembled.
Aug 11, 2017 | Hyundai ImageQuest Q995 19" CRT Monitor
P1110 Blurry/dubble image
your beam needs calibration take it 2 a pro... windman
Jan 28, 2006 | Dell UltraScan P1110 21" CRT Monitor
Dell E173FP 17" LCD Monitor Logo
1,573 people viewed this question
Alun Cox
