Question about Kenmore 15864/15862 Top Load Washer
Water will not drain
Kenmore 110-26922502. water will not drain. i took the motor down and it turns on but when mounted it will not start. it make buzz sound and turns off so i turn the knob off for a few seconds and it resets then i try to turn it on and it does the same thing. motor gets hot too.
  • gmonqueen123 Feb 06, 2009
    We have seem problem with our will not Drain, and make noise sound.
    Scholar:
  • 99 Answers
Hi my name is joyce
sounds like you have a issue with your pump, I have had a simular problem with my washer and I had to call a technician out to fix the problem, if you need assistance in getting help with someone in your area to come and take a look at your problem let me know and I will help you.
thanks,
joyce
Posted on Feb 06, 2009
How to fix a Kenmore dryer model 417.8112 with error code pau
Is your washer still full of water? You may have something in the drain motor, that would also cause the error code 41 issue. I'd first check for an obstruction in the drain motor itself. Its very easy to get access to the drain motor. Lots of times I see these get clogged with stuff ...
Jul 27, 2014 | Kenmore Dryers
My kenmore diswasher model#363.153221100 when i start the wash cycle starts to fill up with water but then drains the water back out immediately and the wash cycle never starts.
Hello & Welcome to FixYa
This problem is caused when the motor goes bad and needs replacement. The control will fill water and then sends signal to the motor to start a cycle, if it won't work then it will drain the water and so won't start the cycle. However, it can also be a bad door latch-lock assembly as if the control senses that the door is not closed it won't start the cycle. If you hear any humming buzzing sound from the bottom of the unit then replace the motor if not then replace the latch assembly. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Kenmore Dishwashers
DIshwasher stopped during wash and won't run or drain.
Sounds like a drain motor startup capacitor, or stuck pump. Try disconnecting power and turn the water pump manually. Some disassembly required. Then after a few good hand spins replug and try again.
Mar 05, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
Whirpoll Type 111 Washer will not spin or agiate. Seems to be noise soft buzz sound. Water will drain out mostly but not spin out. Pump looks like it is working. Switch makes a clicking sound and seems...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Oct 26, 2009 | Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Buzzing sound
a loud buzzing sound it is probably a faulty control/timer module.
If the appliance works the same, you can keep it like this, if it still under guaranty, call the number listed on the owner manual to get repair.
If you got the sound only recently, that means that the control is going to fail soon, in that case call a repairman and have the control assembly replaced.
You find diagrams and parts here,
just enter the model number.
Oct 10, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
Can't wash -
the motor is buzzing i presume did you take the cabinet off?? Check the motor connector look at the red wire make sure it isnt burned.
Sep 28, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Does not drain & makes a loud buzzing sound(KENMORE 44042)
this sounds like something has gone into the pump, coins or whatever, the objects need to be removed, also check the hoses, remove the plug to work on any appliance the buzzing is the pump trying to work but unable to go round, start there and see how you go if i have helped rate me please
Sep 12, 2007 | Kenmore 44042 Front Load Washer
Kenmore 15864/15862 Top Load Washer Logo
61 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
