Question about Acer Aspire 5520-5908 Notebook
Low usb power out
Every so often ( meaning irratically, but often) the light on the middle click button on my usb powered optical mouse will dim and the on-screen cursor will begin to move in a jagged manner. The mouse is the only item plugged into a usb port. I am doing nothing special. It happens when the fan runs and when it doesn't. It's happened running applications and not running applications. If I disable all other usb ports will all power route to the one with the mouse?
  • 115 Answers
The captr of the mouse is dirt, clean it.
Posted on Feb 06, 2009
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
Mouse unresponsive and red light flickering. you have to click the mouse to make it responsive again.. but if you leave it a little while the same procedure again
It sounds like the mouse goes on standby to conserve battery power, or the batteries are getting low. It's more likely it goes into a low power mode to extend battery life and conserve power.
Dec 19, 2009 | Logitech Cordless Click Optical Scroll...
Receiver will not light up so the mouse nor the receiver works? help
The reciever for this mouse does not have a light, however, your USB might be a dud (on your computer) so try another port. Also replace the batteries inside your mouse with new ones. This should fix the problem. Then reconnect them with the button on the reciever. Also make sure to hit the power button on the bottom of the mouse. If this does not work, then your mouse if fried and you need a new one.
Oct 02, 2009 | Logitech LX5 Cordless Optical Mouse -...
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Jul 21, 2009 | Microsoft Wireless Optical Mouse
IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Jun 02, 2009 | IBM Optical Travel Mouse 2224P0480
It's not working right....
The BenQ M310 mouse needs to "sync" with the USB receiver. Need to push the two buttons at the same time, or maybe the one in the mouse first then push the button in the USB receive so the two can "sync" to each other. This may solve this problem. Good luck!
Feb 16, 2008 | BenQ M310 Wireless Mini Optical Mouse
Google Earth
I have a LX5 cordless mouse that was part of my S510 desktop set. Prior to this set I had a seperate USB keyboard and generic optical usb mouse. I noticed after installing the SetPoint software that i lost all use of the middle mouse button. Here's how you can restore the use of the middle button. SetPoint reassigns the middle button so that it no longer functions as the default middle button function. This can be changed in the SetPoint configuration. (Look for the icon in your system tray) Click on My Mouse and select the middle button. It's number 3 on my list and was originally titled zoom, but, clicking on a button name will give you a picture of the button location on the picture to the left. Once you locate the middle wheel button, in column next to the list, under select task, select other, then from the drop down list, select middle button. apply and save your settings by clicking ok. pan and tilt will now work properly in google earth.
Jun 13, 2007 | Logitech MX1000 Laser Cordless...
Acer Aspire 5520-5908 Notebook Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
