Question about Dell Dimension 4700 PC Desktop
BOOTING PROBLEM MY COMPUTER ACTS LIKE IT'S GOING TO BOOT NORMAL SHOWING ME THE WINDOW START UP BUT THEN IT GETS TO A POINT IT STOPS AND IT JUST SITS ON THAT SCREEN UNTIL i FORCE IT TO TURN OFF. ON THE SCREEN IT IS COMPLETELY BLACK AND ALL I SEE IF MY CURSER WHEN I MOVE THE MOUSE ALL MY SEETING ARE ON MY HARD DRIVE BECAUSE I HAVE THE NET GEAR PROGRAMED AND I CAN USE THAT ON MY LAPTOP AND GAME IN ANOTHER ROOM. HOW AND WHAT DO I NEED TO DO TO GET IT BACK UP.
  • 1 more comment
  • vaec_men02 Feb 06, 2009
    i see the screen with safe mode but the only think i can do is move the curser.
    i did this but it doesn't let me do anything because it only gets to the black screen but it does not load the programs
  • Chris May 11, 2010
    Can you boot into "Safe Mode"?
    Here's how:
    1. When you push the power button, wait until the DELL screen goes away, then tap the F8 key a couple of times.
    2. You should now see a screen that gives you several options. I'd suggest choosing "Safe Mode".
    3. You'll see a bunch of text scroll by and it appear to pause for a few minutes, but eventually, you should see a desktop and have mouse control.
    4. If that happens, then read the window that pops up that talks about Restore Points. You might try that option. Try to restore to a date before this happened, allow it to restart and see if that helps.
  • Dell Master
  • 2,404 Answers
When you turn on your computer press F8 to pull up a bootup menu and choose safe mode and see if you can get into safe mode. If you can then go into MSCONFIG under the startup tab and choose disable all and reboot. These are all of the programs running normally when you startup the computer. If you get back into windows normally then that means there is something loading up upon boot that is affecting windows. Try to figure out the last thing you installed before the problem and uninstall it.
Posted on Feb 06, 2009
Dell min laptop ,Error message says Delete restoration point and proceed,What does it mean
The restoration point refers to it being placed in hibernation. The computer loads all the active ram into a portion of the hard disk and then when you boot your computer it loads is back, however if this portion on the hard drive is corrupted you may not be able to boot up and it will give you this message, As your computer is booting you can hit space bar and it will let you delete and start normally, If you press F8 right before the point windows starts booting you will have other options and can start windows normally through there.
May 03, 2010 | Dell Tablets & eReaders
Windows xp boots but the desktop will not come on
well there is a couple of thing you could try 1) power on your computer press F8 rapidly and select "last known good configuration" 2) power on your computer press F8 rapidly and select safe mode login with your account and press yes to restore you computer to an earlier time select a date tah the computer worked ok and click on restore
try it and please if you have any problem please comment
Apr 01, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Windows xp boots but the desktop will not come up
Log in using SAFE MODE. While laptop boots, press F8 and it will prompt for which mode to login. Select 'SAFE MODE'. Once logged in try to restore the OS to a previous good restore point.
If you've a backup of the registry key, it will help better. Just restore the registry from the backup instead of going for an old restore point.
Please come back and rate my solution if this turns to be helpful for you or also if you need more clarification. Thnx
Apr 01, 2010 | Computers & Internet
Hello: I have a computer running Windows XP Media Edition SP2. Several weeks ago, I started experiencing boot up problems with my computer. It stops booting in normal mode. It will boot in safe mode. When...
It looks like you installed the wrong drivers for your motherboard.  It can cause a Blue Screen Of Death.  Also how many hard-drives do you have in that computer?  IDE?  Are the jumpers set to CS?  I find that CS causes problems.  If you have 2 devices on a ribbon cable make one master w non ATA   and the second device as slave.  Also the boot.ini could be confused.  Is the boot.ini on the wrong hard-drive   Did you accidentally put 2 operating systems on the same computer?  lots of things could have caused this.
Nov 09, 2009 | Microsoft Windows XP Professional
Computer wont start up fully
Your boot menu for Windows is corrupt. Try to boot from the windows installation disc and make sure to key any key when told to boot off the disc. Once the windows files load, you will have a choice of what to do next. If you have XP, choose the repair option and you will be faced with a black DOS screen...after the blinking cursor type
FIXBOOT hit enter
Try to boot the computer without the disc in it. If it does not boot, then boot off disc again and this time type:
FIXMBR hit yes and enter
Try once again to boot without the disc.
Also try to boot into safe mode by tapping F8 when you see the Compaq name come up during starting. If you can get to the multiple boot up option screen, scroll to "Safe mode with networking" and choose that. If it boots then you can go to the start button > accessories > system tools > system restore > choose a restore point back a day or two and follow the prompts.
If you have Vista, boot off the disc and choose start up repair. If that doesn't work, boot again and choose restore computer to an earlier time. Again choose a restore point back a few days. Good luck ParrotHead PC Repair
Sep 06, 2009 | Compaq Evo N610C Notebook
Won't boot up, windows won't start successfully
In fact, your computer is restarting by itself after a problem. On Windows 98/2000 the blue screen was sitting there until you rebooted the computer. Windows Xp reboot the computer sometimes even without showing any error message. The thing is, if it reboots even if you select Safe mode, something may be wrong in your hardware (i.e. your memory or hard drive). I would bet on a memory failure but it's hard to be sure unless you boot your computer with a memtest CD, you can find it for free the internet and select your CD as booting device when the computer starts. If you cant do that yourself, you can bring it to a local computer store or anyone with good computer repairing skills. If you need more help with this, let me know
Jun 08, 2009 | Toshiba Satellite A105-S171 Notebook
I was playing online games on my sony vaio. Suddenly I got blue lines on the screen and the laptop stopped responding. So I tried restarting the laptop but I get blue thin vertical lines before the laptop...
Blue thin lines before it boots will rule out an operating system or driver fault. So it would appear something in the machine has failed.
Do you have a VGA monitor you can connect to it and see whether it shows the fault? This will show that if the fault also shows on the external monitor, it is likely an electronic fault on the main board, whereas if it works on the external monitor but not on the built-in monitor, my guess would be the cable that goes from the main board up through the hinge of the screen into it, or a connector, or an actual fault with the LCD display.
Windows booting normally once the display drivers were disabled indicates to me that Windows is no longer detecting the faulty display and therefore boots normally - possibly pointing to failed electronics in some way. It could even be corrupt BIOS that controls the video or something along these lines, though that's unlikely.
Good luck, either way it sounds like it's off to a computer repair shop. Is it under warranty?
Apr 27, 2009 | Sony VAIO VGN-SZ460N/C Notebook
EVERY TIME I TRY TO TURN ON MY DELL COMPUTER IT ACTS LIKE IT IS ABOUT TO START UP BUT THEN GO TO A BLUE SCREEEN AND GIVE ME A ERROR MESSAGE AND WILL NOT GO ANY FURTHER
BSOD = Blue Screen of Death
You have a problem with Windows booting.
When you computer starts up and it has passed the bios check start pressing F8 until you get the Windows start up options, select safe mode and see if windows then boots normally.
If it does then search/run msconfig.exe, on the General tab select Diagnostic startup, click OK and reboot and see if windows now loads.
If it does then you have a program or driver installed that is conflicting in Windows, so remove any recently installed programs or hardware drivers
Go back into msconfig and select Normal startup and see if Windows boots again.
See how you get on with that
Apr 19, 2009 | Computers & Internet
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | Computers & Internet
Volume control
Try to boot into Safe Mode (windows 7: press F8 on boot, or Win10: start: type msconfig, enter, then boot tab: [x] Safe boot, press enter). It will be more successful more often in Safe Mode, but whether you can get into Safe Mode or not, click Start, type System Restore, press enter. (You may have to go to System Properties: System Protection tab, then System Restore.) When you restore to a previous restore point, you may find the weirdness to go away. If your problems are due to malware having been installed, you may have to choose restore points further and further back in your restore point history until you get back to before the malware, then the badness goes away. System Restore does not affect your data, only the Windows files.
Apr 03, 2017 | Qtronix Scorpius 98N Plus Keyboard
Dell Dimension 4700 PC Desktop Logo
113 people viewed this question
Alun Cox
