Question about Kenmore Washing Machines
Won't spin but will drain.
Won't spin on its own but will a little if you help it with your hands. HELP!!!!
Replaced the clutch
Posted on Feb 06, 2009
Sears laundry center 92702 burning smell and won't drain spin out
If the motor is running and it won't drain or spin, then the motor coupler has failed and needs replacing. Here is a link to the part.
Here is a video to show you how to replace the coupler. If you could post the model number that is located on the unit I can get you the service manual to help you a little better.
Oct 18, 2012 | Sears 24 in. Electric Laundry Center with...
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
My Indesit WIL163 is stuck washing - won't go on
I suspect that the logic board has developed a fault and probably needs replacing. 'Phone your Indesit Service Centre and get an engineer out. I believe a replacement board costs about £100 fitted, but a 12-month service plan paid monthly may be a bit cheaper, and will cover further breakdowns. Unfortunately, these boards are not the most robust or reliable examples of technology.
Turn off the power to the machine; preferably unplug it.
If you can open the door(?), bale out the drum by hand. I don't think there's a pump/filter access panel on this machine, so it's not easy to get the water out. You could try
disconnecting the discharge hose from the pipework, then lower the open end over a washing-up bowl so that the water drains from the drum by gravity. It depends how close to the floor you can get the open end. When enough water has drained, it should be possible to open the door to remove the laundry. Sorry, this may take a while.
Hope this has helped.
Jan 11, 2018 | Washing Machines
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Won't spin and drain
The most likely problem is that the drain pump screen is clogged so its not draining and if it isn't draining it wont spin.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage,
Good luck,i hope this helps
Aug 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have an ecosmart Fisher&Paykel. Goes OK through all the cycles until the spin. Won't empty water. Tried rebalancing load, and it is level. Manual says it could be a suds build-up and to do a deep...
Hi there, it sounds like your drain pump is not working. Tip the washing machine back and look underneath. The drain pump has a little black fan on it. Disconnect the hose to see if there's anything stuck in the drain, like coins, hair clips etc. Clear out the pump and remember to reconnect the hose securely before trying out the washing machine.
Please remember to rate this solution, thanks.
Jul 01, 2011 | Fisher and Paykel Washing Machines
Washes but won't spin or drain
check the safety switch on the door of the machine, if its not working the washer won't go into the spin cycle , if you need help in checking it, or how to,, feel free to contact me back by replying to this amswer
Jun 16, 2011 | Whirlpool Washing Machines
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Good evening, My Roper washer RAX4232PQ0 will not seems to drain OK but won't spin...can you offer any help? Thanks!
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
Jun 09, 2011 | Roper RAX4233PQ Top Load Washer
Washing Machines Logo
14 people viewed this question
Sal De
 Brian Main
Brian Main
