Question about Honeywell L4064B2236 Fan/Limit Control Heater
Oil furnace fan on all the time
I have a carrier oil furnace with a honeywell st9103 control. The fan is on all the time and the burner will not fire
Who cares
Posted on Feb 06, 2009
Low voltage chatter to the right of the cad cell relay
Cad Cell Relay Control Guide: heating system reset switch ...
inspectapedia.com/heat/Cad_Cell_Relay_Reset_Button.php
LOW VOLTAGE WIRING REPAIR UPGRADE ... LARGER VIEW of an oil burner Cad Cell Relay by Honeywell ... The gray box in the right in this illustration. ... motors including those operating air conditioning fans, heating system oil burners, ...
Oil furnace cad cell and relay - YouTube
? 11:31
https://www.youtube.com/watch?v=SHTwhOtvQWE
Mar 30, 2012 - Uploaded by grayfurnaceman
Explanation of the operation and troubleshoot of the cad cell relayand the cad cell used ... Yeah there's oil and I have tried but I'm not sure if I reset right .... i think it's supposed to be 160 on thelow limit 180 on the high limit....Missing: voltage ‎chatter
Dec 16, 2015 | Heating & Cooling
Need wire diagram from the hot wires feeding a blue angel oil burner and blower motor
Dean,
What kind of primary control? Beckett?Honeywell? Carlin? Control model #?
Oct 18, 2013 | Peerless WV-DV-04, Oil Fired, Hot Water...
Carrier oil furnace model 58BMA155-20(FORCED HOT AIR)i had changed the blower motor & honeywell st9103a128 fan control board.now the blower motor won't shut off until the breaker is turned off.i...
You need to check the wiring to the limits and safety devices with are in a number of locations, make sure all connections are tight.The most common cause for the blower to run is the high limit device which is the one mounted above the burners on the flat metal panel with two wires.
Nov 03, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Have old Carrier standing pilot furnace. Furnace calls for heat, but blower does not come on for almost 1 minute. How can I make blower some on sooner??
If it has a honeywell fan control, the cover can be pulled off and the setting can be lowered by adjusting the small lever on the dial, if it is a timed control it probably has no adjustment unless it was replaced with an adjustable fan control.
Oct 30, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace ran out of oil,got oil for the furnace,started furnace ran for 10 secends then switched off
On the oil pump there should be a bleed screw. Attach a tube to it and the other end to a can and 3/8" wrench, restart burner by depressing red button on Honeywell control and open up bleed screw. Oil will start flowing into can. When full stream of oil coming out of hose, tighten bleed screw. You have less than a minute to do this or the Honeywell control will shut off burner for a minute. It may take more than one try.
Jan 18, 2011 | Heating & Cooling
I have an olsen oil furnace, the problem is the burner will shut down 5 or 6 times before it reaches the set temp, the fan limit control is set at 90 and 120, its a honeywell limit control.
Hello A couple of things.If burner is cycling on high limit ,it can be a air flow problem.Change the air filter.Check the blower wheel that is reasonbaly clear/clean.Also check the intake grille that it is not blocked and all the supply grilles are open.Also mabey the nozzle size can be steped down if the input is too high(a slightly smaller fire).If the blower fan on/off is the problem (as the burner is seperate) raise the 120*f pin to 130*f but hold the wheel disc steady during adjustment.Leave the 90*f at 90*f.
Sep 14, 2010 | Honeywell Heating & Cooling
Honeywell thermostat TH6110D1021. Blower comes on
Hi, You are right, fan is on a time delay in the heating cycle, and after burners fire that is when this delay comes into play. You have a preset factory temperature that determines the cycle on time for the fan, and the off time after the burners shut down also. This will not be in the thermostat, but in the fan/limit control the is mounted on the face of the furnace, with a probe inserted into the fire box.Depending on how old or new this unit is, will depend on the type control you have.It may be just a high limit switch, or the 1st I mentioned.If so, It rotates in the burner as the temperature rises, to turn the fan on and off.Disconnect power, remove cover, and 2 screws.Slowly remove the control and gently clean the probe. Turn the dial if this one has it and you will be able to hear it click. This click is contacts closing to start fan operation.Reinsert and try again. If problem continues, you will have to replace it.They do tend to stick closed/on, in the heat cycle from time to time and a cleaning sometimes will solve this problem. Not knowing how old this furnace is and type, make it difficult to give you a correct diagnosis, so check this fan control as I have explained, and if your system is of a different type, please let me no so I can correct this problem. Sincerely,
Shastalaker7
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
Fan shuts off too soon after oil burner stops
That is an old style t-stat i would replace it with a more up to date model. Your problem may be in the limit switch. But yes to answer your question most fans can be adjusted just depends on if it has a manual limit that looks like a silver box on the interior of your furnace or if it has a mother board control system.
Jan 04, 2009 | Honeywell Power Humidifier: Furnace...
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
Turning on the heat makes a loud noise then i turn it off and just run the fan no noise
This sounds like an oil burner, which would mean your getting an oil biuld up in the fire chamber when the burner fires up. If it is a gas furnace you need to ajust the air flow.
Oct 03, 2008 | Carrier Heating & Cooling
Honeywell L4064B2236 Fan/Limit Control Heater Logo
348 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
