There are no active mixer devices available. To install mixer devices go to Control panel, click add printer or other hardware, then click add hardware. Tried to do this a list pops up but there isn't a listing for speakers.There are no active mixer devices available. To install mixer devices go to Control panel, click add printer or other hardware, then click add hardware. Tried to do this a list pops up but there isn't a listing for speakers.
There wouldn't be a listing for speakers, you'll want to look for Multimedia Devices, but let me backtrack first.
Do you have the latest and correct driver installed? Usually when you install a driver, it take care of adding and setting up all of the neccessary devices.
Just to clarify also, is this the correct model of your motherboard : D945GPM ?There wouldn't be a listing for speakers, you'll want to look for Multimedia Devices, but let me backtrack first.
If the volume control is all grayed out, locked like you said then your sound driver is missing or corrupt. You will need to re-install the sound driver.
go into control panel, Hardware and Sound click on the sound and the Volume control should pop back up for you i hope this was helpful don't forget to rate
Hopefully this helps. Right click on your volume control icon. Open the "Volume Mixer," and make sure that nothing has the mute X on. Then right click on "Volume Control," and make sure that the volume control is checked to play all sounds, and that your Speaker box is checked. Next step is your music, if the sound was muted directly @ the music playback, this could be the problem. Open your Media Player and try to play music, if you cannot hear it, click on the mute button to the song playing. If your Player was shut off in the "mute" mode, then you will not hear sound. It Happened to me once. You will need to check all of your "Players" to see if any of them were shut off in "mute."
you have to make sure you increased the volume on the computer itself.go to the control panel and click on sound,speech and audio devices.change the volume settings and speaker settings.this should bring about the desired result.
dirty switch. I took my 2009m apart and cleaned the switches with alcohol on a qtip and the problem's gone. Not too hard to do. Leverage the case gently with a putty knife or something and it will pop open. Then pop around the edge to remove the back completely.
Hello....No Sound, No Volume Control, Mixer not Found, No Sound device installed…etc etc, This is a generic issue with Windows OS....many of the users are facing this issue.... 1 - r u facing NO Audio/Sound issue...? 2 - is ur Volume Control not responding ? 3 - is ur Sound and Audio Device in Control Panel Grayed out ? 4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
if ur ans to any one of them is Yes...then u are being spammed by Microsoft....ur Sound Control IRQ is being frozen by a recent update from Microsoft....NOTE..VERY..IMPORTANT...no file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it…. Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service. www+sureshayyar+110mb+com Copy the above address in the browser, replace + with dots....all the best...
You just need to reinstall the audio drivers for your soundcard.
If you provide the model number for your motherboard I can help you locate them. Installing is very easy after that, Just run a setup program.
The motherboards model number will be printed on the board in failrly large letters and numbers. You may have to move a few things out of the way to find it though.
If your not comfortable opening the side of your computer then download CPU-Z unzip it and install it. It will give you the information needed without having ot open your computer.
Task tray menu usage
You can turn on and off the features by right-clicking on the TOSHIBA Virtual Sound's task tray icon. You can also select a listening mode with this menu.
Task tray icon menu (Off)
Task tray icon menu (On)
Listening environment menu Task tray appearanceThe task tray icon will blink when an audio filter is running. If you move a mouse cursor over the icon a pop-up message appear, then it will show a state of the audio filter.
The message which will appear when the SRS WOW HD is available
The message which will appear when the SRS TruSurround XT is available
The message which will appear when the SRS Circle Surround Xtract is available
What operating system are you running?
whats the error message?
Could you try posting the message again? It doesn't show up.
