Question about Amana AMV5206 Microwave Oven
Replace microwave light bulb
I can't find access to Amana microwave oven light. Need to replace bulb.
Amana model # AMV5206BAB
  • 1 more comment
  • mike60101 Feb 06, 2009
    front cover is off, how do i remove bulb?
  • mike60101 Feb 08, 2009
    Manual disappeared with ex-wife....LOL
    Thank You for your help, Mike
  • Anonymous Mar 15, 2014
    Amana Big Oven Ignitor will not light oven
  • Amana Master
  • 9,086 Answers
See page 24 of the owner's manual here:
Posted on Feb 08, 2009
How do i replace a faulty diode on my amana AMV5206BAB
If you need to ask this sort of question, then I suggest you should not try to do it yourself. You will need a temperature controlled soldering iron, a way to remove the old solder (solder de-sucker), new solder and the right diode. It is very easy to damage a circuit board doing this so you need the right skills.
May 23, 2016 | Amana Microwave Ovens
How to replace light bulb in combination oven model acm1580ab
Cannot find your model number, please provide make and model.
Jul 23, 2008 | Amana Microwave Ovens
Amana Microwave over the stove. Need to replace light bulb. So what is the part number?
If the model number is correct in your post and I assume you are talking about the over the range light and not the cavity light then you need 53001905 halogen bulb, charcoal 53001442 still available
Jan 17, 2015 | Amana AMV5206AAS Microwave Oven
I have a amana microwave mn acm1580a how do i remove the bulb
The external cover has to be removed to gain access for lamp replacement.
Jan 12, 2015 | Amana Radarange Microwave Oven
Replacement door
This, I have found, is one of the best places to obtain Amana parts. I hope this is helpful to you.
http://www.repairclinic.com/Amana-Microwave-Lighting-Light-Bulb-Parts
Aug 25, 2013 | Amana AMV1150VAQ Microwave Oven
Changing microwave light bulb
Check the owner's manual to see if yours is a model which allows access to the lights without pulling it down from the wall.
Accessing the lights on some models will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Many use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
You can find handy exploded views and order parts by model number here.
Oct 06, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
Trying to replace a light bulb on an amana microwave
The lamp on this model is an assembly - bulb and socket mated together.
It is mounted in an air duct on the right side of the oven near the magnetron.
You'll have to remove the outer cover to get to it.
You can find helpful exploded view diagrams and order the bulb by entering your full model number here.
Dec 09, 2008 | Amana ACM1580AS Microwave Oven
Amana AMV5206 Microwave Oven Logo
394 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
