Question about Canon PIXMA iP1800 InkJet Photo Printer
How do you load the paper in cannon ip1800
How do you load the paper? I think its in there correctly but if I try to feed paper it sounds like it is trying but the paper never moves.
  • 2,229 Answers
If the paper is loaded correctly--that is, placed in the paper holder and the side guides are tight against the paper, then the printer may need cleaning or it is defective. Check that there is not too much paper in the tray.
Many time the little rubber rollers that grab the paper become glazed and will not pick the paper up. Also, the feed mechanism may have just worn out.
If this is an older printer, it might need to be replaced if you can't find a shop to clean it for you.
Posted on Feb 06, 2009
Printer wil not feed paper in -keeps trying but paper will not move in.
Hi Jamieos,
Turn the printer off and on.Solved?
Turn the printer off and disconnect from PC.Unplug from power.Reboot the PC.
Remove the papers from the feed tray and look through the paper path for any obstructions.
Load the print papers and make sure they are correctly aligned on the feed tray.
Cear any print queues on your PC.
Connect everything now and start the PC.
Try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
Paper not feeding properly, nothing jammed as I have checked. Loading tray having problems.
Check to see if the printer is actively trying to feed the paper. If you hear it trying to feed and see the wheels turning, but the paper won't feed, check to see if a screw securing the feed wheel has come loose. If you hear the sound, but nothing moves to pull the paper in, then you probably have a bad printer. They're too cheap to replace to bother fixing - so get a new one.
May 25, 2009 | HP COLOUR LASERJET CM4730 F MFP Printer
"out of paper" message
If the printer says out of paper try to reset the printer is this does not help
then its hardware failure on the printer ,,you can try this steps:
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck un
Feb 16, 2009 | HP PhotoSmart 7350 InkJet Printer
I receive out of paper message with paper loaded and ready
Try these steps :
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 27, 2009 | Lexmark X5150 All-In-One InkJet Printer
Paper feed
Check tray 1 there should be an arm hanging down in the center of the tray the arm goes thru a slot in the metal plate. This arm moves when you install paper in tray 1. If the arm is missing or not in the slot the machine will think paper is in tray 1 and try to feed from tray 1. You can try changing the paper size setting for tray one to something other than the size in tray 2.
For example If tray 2 is set for 8.5x11 set tray 1 for legal.
The machine should then pull the correct size based on the print job.
Hope this helps
Jan 21, 2009 | HP LaserJet 5si Printer
Paper Will Not Load
Nov 10, 2008 | Epson Stylus Photo R220 InkJet Printer
Lexmarkx73 Won't feed paper through while printing
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
Printer paper loading problem
Jul 05, 2008 | Epson Stylus Photo R300 InkJet Printer
Samsung SCX-4216F feed wheel
Clean the Feed Roller In the middle of the printer. Take the paper tray out- you will see the roller in the middle. Send a print job with paper tray removed. Press the black thing to fool the printer that it has paper. You will see the feed roller move. When it is in the position you want to clean- open the toner door and it will stop moving so you can clean it. Isopropyl alcohol and LINT FREE CLOG.
Nov 07, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Paper will not feed into printer
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
202 people viewed this question
old marine
old marine
