Question about Compaq Presario 5000 PC Desktop
Compaq presario 5300us
I need a complete wiring guide for the motherboard and pin settings
  • 2,692 Answers
Link to everything that is available from Compaq/HP for you computer model:〈=en&cc=us
Posted on Feb 06, 2009
I have a compaq presario sr1617 and i need help plugging power supply back into the motherboard i was not the one who disconnected and i am left trying to reconnect
A crude manual/guide is available here
There are two power supply connectors labeled AT12V small square 4 pin upper left corner and 24 pin rectangular and ATXPWRR1 upper right between memory slots and floppy drive connector
Mar 13, 2017 | Compaq Computers & Internet
How can I get my Compac Cq58 back to factory settings
the main board should have a jumper that is labeled CLR CMOS you need to switch the jumper the pins 1 & 2 over to pin's 3 & 4 make sure you understand that this is for the mainboard factory reset if you're looking to reset the computer's operating system and programs to factory settings that is a different procedure.for that I believe you need to hold down the f12 button well you're turning the device on hold the button down until you get a menu the menu will guide you through the procedure
Nov 19, 2014 | Compaq Presario CQ5810 Desktop Computer...
How to repair speakers for compaq presio c700
The first thing you do is go to HP Support > Compaq Presario C700 Notebook PC > Main Support page > Manuals > Service Manual,
HP G7000 Notebook PC and Compaq Presario C700 Notebook PC -
Maintenance and Service Guide
Then go to Page 13 - Illustrated Parts Catalog.
Then Computer Major Components - Page 14, to end on Page 16;
6) Speakers - 454946-001
It's an HP part number so type - HP 454946-001 in your browser search bar, and press the Enter key,,Laptop,Part,454946001.aspx
Dec 21, 2012 | Compaq Presario C700 Series Laptop...
How to re-wire a Compaq Presario SR2150NX Case power Switch
The plastic front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
The Front Panel header contains connections for the Power On switch, Power On LED light, HarDDrive activity LED light, and so on.
(Look at the motherboard photo. The Front Panel header is at the bottom right. Scroll down for the motherboard illustration )
There are 9 contact pins.
4 across the Top row, and 5 across the Bottom row.
The four pins across the Top row are numbered EVEN.
From the Left side going towards the Right side;
Pins 2, 4, 6, and 8. There is NO pin 10, just a blank spot.
The five pins across the Bottom row are numbered ODD.
Pins 1, 3, 5, 7, and 9.
A) Pins 2 and 4 are for the Power On switch
B) Pins 6 and 8 are for the Power On LED
(LED is dim when the computer is on? Switch the wires around )
C) Pins 1 and 3 are for the HarDDrive activity LED
(LED is dim when the harddrive is operating? Switch the wires around)
D) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
How to know which wires are for the Power On switch, Power On LED, and HDD LED?
Follow the wires into the Front Panel. Remove the Front Panel, and follow them.
(Need guidance removing the Front Panel post in a Comment )
For additional questions please post in a Comment.
May 02, 2012 | HP Compaq Presario SR2150NX PC Desktop
Where can I get a scematic of a wiring diagram for our compaq presario sr1675cl PC.
this is all I could located ..but get the mo bo name and make a search for its manual (user guide) in there will be much more complete in the actuall plugs and pin wireing numbers and position ...
May 30, 2010 | Computers & Internet
Bad front USB ports on a Compaq Presario 5000
please re-insert the cable of the usb to the motherboard. i believe that there are 4 pins on usb1. now if this usb1 doesn't work, try the usb2. be careful when inserting the cable.
Mar 05, 2010 | Compaq Presario 5000 PC Desktop
Need Power Pin Outputs for Compaq Presario Motherboard
Orient the motherboard so that the Memory Slots are at the top of the board as you look down upon it, and the white plastic power connection is at your left also at the top of the board.
The power switch block of pins should be at your right hand and also at the top of the board in a line with the power connection and the top of the memory Slots and identified as such, but since you have been persistent in asking, I assume they are not so carefully identified.
If you do not have the other connections assembled on the rows of black plastic with copper colored pins where the connection to power is located, simply use a magnifier to locate the paint that SHOULD be located on the printed circuit board identifying the power switch, the hdd switch and the fan power connecter and note the POWER indication located on the motherboard in white paint. The jumpers or white pieces of plastic should also be located in this area, as a guide.
Compaq does not provide such a diagram as you request, but does have a PICTURE of your motherboard located here halfway down the page in the form of two alternatives.
Apr 07, 2009 | HP Compaq Motherboard
Compaq presario 5300us desk top
I suggest you should download this software and run it, find the motherboard model number and get its user manual from manufacturer website
Feb 06, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
139 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
