Question about Casio FX-250HC Calculator
Substitute for 1/X key
I just purchased a Casio fx-300MS calculator and it does not have the 1/X function key. How do you substitute for this operation?
  • Anonymous Mar 18, 2009
    1/x
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Use the x^-1 key, second row, far left. 1/x is x to the -1 power.
Posted on Aug 05, 2010
How do you put in radicals in the casio fx-300ms
Use the square root key. For roots of higher index, use the xRoot key; the shifted function of the Y^x or [^] with exponent 1/3 for cube root, 1/4 for 4th root, or 1/n for the n-th root.
Jul 14, 2014 | Casio FX-300MS Calculator
How do you solve radicals on the casio fx-300ms
To calculate radicals use the square root key. For higher index roots use [SHIFT][X^y]. You need to enter the index before pressing the key. Or use the general power key but with exponent (1/n) where n is the index of the root.
How to take anti log in casio fx 991 ms and give example?
Depending on the actual log function you are talking about, the inverse function (what you call the anti log) can be one of several things.
The inverse of the natural log (LN) is the exponential function e^x.
If y= ln(x) then x=e^y
On a calculator functions that are inverse of one another share the same physical key. If one function is marked on a key, the inverse function is usually the SHIFTED (or 2nd) key
The inverse of the common (decimal logarithm) is the power function with 10 as base.
Example: if y= log(x) then x=10^y
For an arbitrary base (must be positive) if y= log_b(x) then x=b^y.
Note: I do not think that the FX-300ms can perform log calculations in bases other than e (natural log) or 10 (common decimal log).
Aug 13, 2011 | Casio FX-300MS Calculator
How to find antilog on casio fx-991MS?
For common antilog, use 10^x, the shifted function of the log key. For natural antilog, use e^x, the shifted function of the ln key. In either case, press the appropriate function and then enter the expression whose antilog you're seeking.
Oct 26, 2010 | Casio FX-300MS Calculator
580g : 1.3kg
While the calculator will help you in finding, rather quickly, the answer to a computational problem, it is no substitute for understanding. Had you remembered that the k means kilo or times 1000, you would have calculated the result right away, by hand or with the calculator.
Let us try again
508 g /1.3 kg=508/1300g = 0.39078 about 0.3908 or 39.08 %
Hope it helps.
Nov 13, 2009 | Casio FX-300MS Calculator
How do you put casio fx-300MS in degrees mode? please help
To change the default angle unit, you press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Grad appear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press the number key corresponding to your case, 1. All angle values you feed the trigonometric functions will be considered to be in degrees. If you use the inverse trigonometric functions to find angles, the results will be in degrees.
Hope it helps.
Thank you for using FixYa and do not forget to rate this free solution.
Nov 04, 2009 | Casio FX-300MS Calculator
How to calculate calculus problem by a scientific calculator fx-991ms
If by calculus problem you mean derivatives of functions, integrals, extrema and such things, I am sorry to inform you that neither the Casio FX-300MS, nor the FX-991MS can handle them. The newer Casio calculator FX-991ES is capable of performing numerical differentiations and integrations. There also graphing calculators by Casio FX-9750G, FX-9860G as well as by Texas Instruments (TI 83 PLUS/TI84PLUS) that are reasonably performant in that area.
Hope it helps.
Oct 19, 2009 | Casio FX-300MS Calculator
Locating the inverse key for trig. functions
hello,
Use [SHIFT] [COS^-1], [SHIFT][SIN^-1] and [SHIFT][TAN^-1] the keys are the same as the direct function, but they are accessed via [SHIFT].
Be carefule with the angle units when handling trigonometric and inverse trigonometric functions
Hope it helps
Dec 07, 2008 | Casio FX-300MS Calculator
Casio fx-82ES scientific calculator
change the mode to stat and then start operating it in statistical mode
Feb 24, 2008 | Casio FX-300MS Calculator
Casio FX-250HC Calculator Logo
77 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
