Question about Mitsubishi MS-A09WA Split System Air Conditioner
Compressor won't start
When I use the remote inside, the unit on the wall starts and blows out air. This air is not cold though. When I check the compressor outside, it is not operating and the fans are stationary. Is there something simple I can look at in the compressor such as a fuse?
  • Ken Bledsoe May 11, 2010
    There is a capacitor to look at do you have a multi meter?
NO soluition really. I was just hoping there might be some simple things I could check. I will have to get a professional to check it out. Thanks anyway.
Posted on Feb 08, 2009
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
HOW DO I CHECK AND CORRECT THE FREON LEVEL FOR MY SANYO KS1271 A/C; WHICH IS NOT BLOWING COLD AIR?
Hire a tech it will be cheaper and safer. You may have a capacitor that is bad and not starting the compressor.
Aug 22, 2014 | Sanyo KS1271 11,900 BTU Ductless...
My air conditioner is blowing warm air on the driver side and cold on the passenger side
see this steps and think with clearly and logically NOT feared. God bless you
checkmark.gif Start with the compressor. Does it engage when you turn on the A/C?
If so, the compressor is working and the A/C system probably contains enough refrigerant to make cold air, so the problem is inside the HVAC unit. Replace the motor that controls the blend air door (this is a difficult job and best left to a professional since it involves tearing apart the HVAC unit -- about an 8 to 10 hour job!).
If the compressor does not engage when you turn on the A/C, see if it will run by jumping the compressor clutch wire directly to the battery (use a fused jumper wire). If the compressor works when you jump it, and the A/C blows cold air, the system contains refrigerant and the fault is likely a bad A/C compressor clutch relay or a bad clutch cycling switch or pressure switch.
If the compressor does not engage when you jump it, the problem is a bad compressor clutch.
If the clutch engages but the compressor does not turn (the belt will start to slip and squeal), the compressor is locked up and you need a new compressor.
If the compressor clutch engages and turns the compressor, but the A/C still does not blow cold air, the system is probably low on refrigerant and needs to be recharged.
Jul 24, 2012 | 2007 GMC Sierra Classic
My central air conditioner is making a whistling noise in the inside unit when the compressor is running. It's not the blower because the noise stops after the outdoor unit shuts off. It's also not blowing...
If there is no cooling (meaning no cold pipes and not blowing cold air) then check the outdoor A/C for any visible/obvious issues; breakers not tripped, no debris blocking the outside unit from passing air through it, etc. If all looks ok, you can start checking some things inside of the unit if you feel comfortable doing so. Also, most indoor heaters have a higher speed/rpm for the fan when the cooling kicks on, and the heat runs on a lower speed/rpm.
Hope this helps James
Apr 05, 2011 | Heating & Cooling
Frigidaire FAS296N2A starting capacitor
If it has a start capacitor the papper hole in the top of the start capacitor
will be broken if the capacitor was shorted I would have the run capacitor frist But if there is not a burnt wire then the compressor may be bad. You can try a hard start kit that pulgs on the two terminals of the run cap to see if the compressor will start but you will need a amp meter to tell if the compressor will continue to run
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Fedders
if it is blowing at all, this narrows the field to a compressor issue, if the compressor is coming on, but not blowing cold it could be that the coils are dirty and need to be cleaned. They can appear clean from the outdside and be dirty on the inside.
Jul 19, 2009 | Fedders AEQ07FBG Air Conditioner
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Mitsubishi MS-A09WA Split System Air Conditioner Logo
222 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
