Question about HP Photosmart C7180 All-In-One InkJet Printer
Ink system failure
Getting a error 0xc18a101 Ink System Failure - error code 0xc18a0101
THANK YOU!!! I tried more than several solution tips and nothing worked. This one did!
It's not even the same model as the one listed, but I followed Steps 1 and 2 - every step of instruction was just as described - and I've got my printer back! Thanks again!exact same problem. I've tried to replace the yellow ink cartridge three times now (not so bright, I know but it seems cheaper than buying another $300.00 plus printer). I've cleaned, tried the reset the error messages, and nothing. I even spoke with some technical support guy overseas (no offense to him) and it's frustrating. I see folks with the same problem, but no solutions.... anyone? Or are we all shopping for a different brand? If so, wha't good?
  • 6 more comments
  • Joanne Ferguson Feb 06, 2009
    The display states to replace the "empty" yellow ink cartridge. It also says it cannot print until that's done... it does give me the option to print in black and white. I have replaced the ink, cleaned, etc. nothing is working. I even tried to update the firmware...
    I tried to re-set (6 and #) and it reset, but still have the ink error.
    To local wonder..... I appreciate your honesty.... but out of despiration, is there ANYTHING else I can try, maybe, huh?
    I am afraid that the solution posted is correct, that I must replace the printer but if there is one more thing I could try.......
    That didn't work either.
    That din't work.
    Nope..... I should get on Consumer reports and look for good deals, or are there any other solutions out there?
    Thanks to everyone. This is a great service and well worth the cost. I'm sure I'll be back. Joanne
  • 38 Answers
A good series of printers is the Dell All-In-One printers. A lot for little. Price range from 60 to around 300. Really durable as well.
Posted on Feb 06, 2009
    Master:
  • 763 Answers
Sir, have you tried calibrating the colors of your printer? there is an application included on the cd driver provided by your printer to calibrate the colors. if this wont help then send it back to the shop were you bought this printer. hope that helps!
thank you for using fixya
CHARCOIS
  • 3,037 Answers
Hi, have you tried the following reset sequence?
Resetting HP Photosmart C6180 & C7180 "system failure" errors:
(might work on other similar models as well)
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
let me know if this works so we can pass it on to future customers
bestdarngood
  • 916 Answers
1. - Press and hold the “*” key.
2. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
3. - Press and release in sequence the “1”, “2” and “3” buttons
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”.
Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”.
Once the initialization process is complete, the printer will print out a Diagnostic Page.
Then turn off and unplug the cords and plug it in again and once the printer is turned on try to print.
  • 6,784 Answers
The main board is locked. this can only be reset by the manufacture. i would suggest buying another printer. this repair could cost way more than a new unit.
    Scholar:
  • 97 Answers
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, if your printer goes off then turn ON the printer and it will reset itself and will print a allignment sheet, this should resolve the issue.
Regards,  raj_p5983
  • HP Master
  • 13,433 Answers
Hi the problem is solved?
  • Ekse Feb 06, 2009
    connect it to a wall socket, turn it on, pull the
    power cord, hold down # + 9, connect the power cord, wait 3 secs or the
    "Initializing Full Reset" appears then
    release the buttons. If the multifunction shuts itself down, turn it on to select the language, align the printer cartridges.
  • Ekse Feb 06, 2009
Error code OXC4B827F
This is an Ink System Failure message. I would try this guide. 'Ink System Failure' or a '0x...' or a 'C2...' Error Message Displays on the Front Panel. To help resolve the issue.
If that doesn't work, please call our technical support at 800-474-6836. If you live outside the US/Canada Region, please click the link below to get the support number for your region. http://www.hp.com/cgi-bin/hpsupport/index.pl.
Oct 12, 2015 | HP Officejet 4630 Inkjet Multifunction...
Error 0xc18a0101 persists. Have tried solution given earlier for 0xc18a0001 without success. Ink system failure not resetting; all cartridges are full.
Its tricky mechanism, once printer detects ink system failed it cannot be resetted. Do this take out cartridges from printer., open right cover., find out logic card., remove cmos battery., wait for 5 minutes., refix batyery., power on the printer., follow the screen messges ... I hope it will solve the issue..
Sep 15, 2014 | HP Office Equipment & Supplies
I keept getting photosmart ink system failure code 0xc18a0101 I have tried turning the printer off and even uninstalling and restalling the printer and it keeps giving me the same error code I have a...
Hello;
Try Resetting the printer
* Switch off the device
* Unplug the Power cable of the device and the usb device of the printer
* Wait 30 seconds
* Plug the power cord and usb back
* Try test print
If not solved try servicing your device
Nov 03, 2010 | HP Photosmart C6280 Printer
Ink system failure and can no longer print. refer toprinter documentation. error 0xc18a0101 turn printer off then on.
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a free step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 24, 2009 | HP Photosmart 8250 InkJet Printer
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Ink system failure
it could be a viros or a printer jam
Aug 16, 2008 | HP - HP Photosmart 8250 printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
67 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
