Question about Refrigerators
Instruction/user guide for Westinghouse Virtuoso Refrigerator
Where can I find this operating instruction? I need to clean inside the refrigerator, can I switch if off from inside. The fridge is positioned in a wall cavity and I cannot easily pull it out in order to switch off at the socket.
  • 10,865 Answers
It is not necessary to turn it off to clean it. If you wish to turn it off though, determine which circuit breaker in your electrical panel controls the refrigerator and turn off the power.
Posted on Feb 06, 2009
Our Westinghouse Virtuoso side by side refrigerator with ice-maker Model RS645V*10 will not make any ice. Would changing the water filter fix the problem or is it a bigger concern?
If you are getting water from dispenser, then changing filter wouldn't help. Is ice maker getting water? Is freezer at or near 0F?
Nov 16, 2017 | Westinghouse Refrigerators
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Alarm keeps going off on Westinghouse virtuoso. Just recently moved and since then it keeps going off every 20- 30 mins. The freezer temp is constantly flashing but not sure what to do??? Help it's driving...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 04, 2010 | Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
A buzzing noise
compressor start device going bad.
Jun 20, 2009 | Westinghouse Refrigerators
How do i change the filter in my westinghouse virtuoso fridge model rs645
Turn power off this avoids water solinoid valve opening.
Locate the filter housing righthand side under master mind control panel on topshelf next.
Remove light cover by pushing bottom rear up and gently pullout.
Unscrew filter cover looks like upside down juicer.There should have been a special white plastic spanner which came with the refrigerator.
Pull filter element down.
Install new element by firmly pushing up.
Screw filter cover in gently don't over tighten.
Turn power on and operate water dispenser to remove air and check for leaks
Apr 17, 2008 | Refrigerators
Refrigerators Logo
468 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
