Question about RCA P52926 52" Rear Projection Television
Television making clicking sound and do not come on
47 in. rca t.v make a clicking sound and don't come on
  • jhebsy Feb 08, 2009
    Chirping when plugged in, nothing else and will not come on
  • Anonymous Feb 10, 2009
    Same problem, dont get it , it just quit and now its chirping
  • 6,784 Answers
This is unfortunately a power supply board failure. it will need to be replaced or rebuilt.
Posted on Feb 06, 2009
My RCA T19060GY TV/VCR will not stay on. When I push the power button on the unit itself (I don't have the remote.), the green indicator light comes on for two seconds and I hear to click sounds
the clicking sound is due to the relay is getting turn on but doesn't stay because of bad component in the power supply board or in the main board. you must check first the bridge type diode and FET transistor using an analog or digital tester.
Aug 16, 2012 | RCA Televison & Video
We have no sound
First, make sure you don't have mute turned on. A no sound condition could be either the 12V or 15V circuit from the power supply is defective, or you have a issue with the main board.
Sep 24, 2011 | Vizio VO47L 47 in. LCD TV
I have a LG 47 inch flatscreen.i cant find any audio output plugs to hook it up to surround sound.how are you supposed to hook it up.
this is from the LG website about that TV.
- Rear,
2 x Composite video/audio input (RCA phono x 3) - Side,
2 x S-Video input (4 pin mini-DIN),
1 x USB (4 pin USB Type A),
1 x Audio line-out (RCA phono x 2),
2 x Component video input (RCA phono x 3),
2 x Audio line-in (RCA phono x 2),
1 x Digital audio output (optical) (TOSLINK),
1 x Digital audio output (coaxial) (RCA phono),
3 x HDMI input (19 pin HDMI Type A),
1 x RGB input (15 pin HD D-Sub (HD-15)),
1 x Audio line-in (Mini-phone stereo 3.5 mm),
1 x Serial (9 pin D-Sub),
1 x Remote control (Mini-phone 3.5 mm)
Mar 20, 2011 | LG 47LC7DF 47 in. LCD HDTV
47" vizio has sound no
Have you selected the proper input for how you have it configured? If using an HD connection, select the HDMI 1 input. If you are using the coaxial cable connection, then select TV input. If you are using the three RCA inputs (yellow, red, white) then select AV input.
Mar 01, 2011 | Vizio VO47L 47 in. LCD TV
I am not recieving sound on two chanels checked all conections even tried it in a different room
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 15, 2010 | Vizio VO47L 47 in. LCD TV
Problem for LG 47LC7DF 47 in. HDTV LCD Television it just flashes red and takes a couple of minutes to turn on and makes a popping sound..
television just flashes red and takes at least 15 minutes to turn on after turning off and on and makes a popping sound.
Apr 24, 2010 | LG 47LC7DF 47 in. LCD HDTV
My 47 inch AOC Hd Tv turns and and has video but no audio. How do I fix this?
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Dec 01, 2009 | AOC L47H861 47 in. LCD TV
RCA Television Turns on and off
check for cracks solder joints on the diodes coming from the flyback
Dec 02, 2008 | RCA P52926 52" Rear Projection Television
LG 47" LCD TV - 47LC7DF Clicking Noise
the old saying is that any issues will likely show up in the 1st 3 days if you run it for 72 hrs. if it dosent fail then it will last.
other than going to the show room and seeing if their unit does the same.
they will likely want to send a service guy to check it out and decide for himself.
Feb 25, 2008 | LG 37LC7D 37 in. LCD HDTV
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Dec 13, 2007 | LG 47LC7DF 47 in. LCD HDTV
RCA P52926 52" Rear Projection Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
