Question about RCA Scenium D40W20 40" Rear Projection HDTV
Light blinks, tv won.t come on
On off light blinks but tv won,t come on at all now
Lamp probably burned out
Posted on Feb 06, 2009
JVC LT46J300 Blue Light blinking TV won't come on all of a sudden
These blinks to standby light are fault indications, called blinking codes. From the number of blinks occur at one time switch on, you can get an idea about the faulty circuit stage inside it. Count it. Visit this site. It has details about blinking codes to many brand televisions.http://electronicshelponline.blogspot.com/Pull up older posts there, either by its left side bar, or see it in Timslide option
Jun 24, 2013 | JVC LT Televison & Video
Blinking orange light
The blinking light is a symptom of power suppply trouble in this type of tv
Apr 21, 2013 | Dell W2600 26 in. LCD Television
My tv kv-xr29m50 won'to on.stand-byl light blinks 8 time
Count the number of blinks occur at one time switch ON. These blinks are fault indications. After counting it, check this link for more details. There are details about Sony blinking codes. Search the site by brand name and model number to your TV in its search box.
Jan 29, 2013 | Sony FD Trinitron WEGA KV-13FS100 13" TV
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
My plasma tv won't turn on only the light
Blinking light usually is a error code if blinks a certain number of blinks and the place to begin is to look for a bad fuse or bad puffed up caps inside on the power supply board--place to begin.........
Apr 16, 2012 | JVC Televison & Video
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
RCA Scenium D40W20 40" Rear Projection HDTV Logo
172 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
