Question about Visual Land V-Touch Digital Media Player
My v-touch wont come on again and i keep pressing reset
  • 2 more comments
  • ani2280 Feb 06, 2009
    diplay is blank in my v-touch
  • amyandcody Mar 08, 2009
    the touch screen on my visual land v-touch is not responding
  • raveena_26 May 12, 2009
    In the beginning my v-touch player froze on the please wait screen and then suddenly stopped when i connect it to my computer it turns without me turning it on with the button but still is stuck on the please wait screen and when i disconnect it from my coputer it goes off suddenly
  • samcnr May 13, 2009
    My V-touch display froze on the welcome screen and wont be reset as well
When mine froze...i treated it like a computer....i dropped it on the floor in my bathroom...(where there's no carpet) came problem since then.....two dollars
Posted on Feb 11, 2009
My kurio wont finish loading how to fix
You cant factory reset it. That only works on apple.
Feb 01, 2015 | Kurio Touch 4S Handheld
I put my pin # on my new pad, now it wont open, how can i get my pad opened again
Factory reset! Press power for about 30seconds so it ends up off! Then press power and volume+ buttons together until reset page appears, select factory reset!
Jan 18, 2015 | Irulu 7" Touch Screen 2gb Android 2.3...
My app won't work on my iPad mini when I touch it
As soon as your iPad starts acting strange, it is time for a reset.
you can do this by simply closing all running apps. Press the home button twice and then swipe all apps up. They are closed then.
If all apps are closed, press the on / off button and keep it pressed till it says swipe to shut down. Swipe and wait till everything is out.
Then press the on / off button again, for a second or so. The iPad starts again.
Somewhat drastic, if you can't switch it of the normal way: Press and hold both, the on / off button and the home button, till the screen goes dark.Then the apple loge appears and again wait till the screen is dark. After that you can switch on again.
If it still does not work, goto settings then general then scroll to the bottom, where it says reset. then reset network settings. It will reset your network settings, but also the rest of the iPad. This is the most dramatic reset, without loosing your apps and documents.
One step further will wipe your data too, so that you must keep for the worst case and only after you are sure you have a backup on your computer from all your data.
Apps can be restored from the App store for free, if you have payed for them, but the data, unless you have backups, will be lost fro ever.
Oct 21, 2014 | Apple iPad Tablets & eReaders
Sharp comfort touch air conditioner screen doesnt show settings and buttons wont work after cleaning. help its hot!!!!!
Switch off the unit at the isolator or fuse box. Leave off for 10 mins to reset. When powering up again and it still wont work, check your remote control batteries are good. Also confirm you haven't "blanked out" the display. Some controls have a display or LED function which blanks out the display so that the lights are not bright at night time. (For bedrooms so that the light doesn't keep you awake) Also check that you have not pressed a "child lockout button" This will stop anything ..
Jul 25, 2013 | Heating & Cooling
My C310a printer wont align
on the front panel press setup >> Tools >> Clean Cartridges
again press setup >> Tools >> Align Printer...
if it does not work then do a reset on the printer
and to do that Press BL/TL/BR/TL Buttons, in sequence
(BL: Bottom left, TL: Top left, BR: Bottom Right) >> Touch Support Menu >> Press Right arrow for Reset Menu and Touch OK >> Press Right arrow for Partial Reset and Touch OK >>
Wait for unit to Power Down/Turn Off >> Press Power button to turn the Printer On...
the printer would automatically align itself...
Hope this helps...
Oct 30, 2012 | HEWLETT-PACKARD C310a All-In-One InkJet...
Screen dissapears after activating call
possibly solution
1.hard reset your device
2.otherwise it maybe hardware issue (touch screen problem)
for : hard reset on the start screen tap -> button then tap setting then about phone, then tap reset your phone and tap yes.
touch screen issue : you need to take to some technician to disassembly to touch screen and reassembly again if with this not solved you will need to change the touch screen. i think this will help you.
Jun 20, 2012 | Nokia Lumia 710
My touch screen will not function. It seems to start okay but the touch screen wont work from that point. I have reset. Garmin NUVI
Turn off the device.
Press and hold the upper-left corner of the screen and turn the power on.
Keep holding the screen and release the power button when the screen is on. Keep holding the screen for next 30 secs and u will see a "press button" on the screen.
at that point release the screen from upper-left corner and touch the press black point on the screen to calibarate it.
should be fine after that.
Jul 29, 2010 | Garmin Nuvi 660 GPS Receiver
G1 got little wet but it dried out and screen shows all but now triangle and cant get touchscreen to work....what do i do?
If it got wet it might still be wet from the inside and that is why your touch screen wont work, You would need to open it and clean it from inside. Or it could have a bad digitizer and that is a second reason why the touch screen wouldnt work. You can try doing a hard reset if you says it just shows a triangle on the screen.
Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle
Now to wipe the device clean:
Press Alt+L. Press Alt+W for a factory reset.
Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Jun 15, 2010 | HTC G1
My ipod touch wont turn on, it shows the little pple symbol on the screen, then flashes white, blacks out, and the apple appears again. I've pressed all the buttons to try to get it to work, but it keeps...
try holding the menu button and the power button for about 20 secs. this will cause it reset, if this method doesn't work, then hold down the menu button, connect it to a PC then hold down the power button, if you have Itunes installed on your computer, it will alert you that it detects an Ipod in recovery mode, basically after that it'll attempt to fix your problem, and it will be able to turn on again.
Jan 18, 2010 | Apple iPod touch
My ipod touch wont work
If iPod touch won't turn on, or if the display freezes or doesn't respond
  • iPod touch may need charging. See "Charging the Battery" in the iPod touch Features Guide.
  • Press and hold the Home button for at least six seconds, until the application you were using quits.
  • If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  • If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Sep 22, 2009 | Apple iPod touch
Visual Land V-Touch  Digital Media Player Logo
387 people viewed this question
Top Visual Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Level 1 Expert
Are you a Visual Audio Player and Recorder Expert? Answer questions, earn points and help others
