Question about Hitachi 65S500 65" HDTV-Ready Rear Projection Television
DVI Connection What is the exact name of the type DVI connection this TV has?  There are many types of DVI (mini-DVI, etc.).  What is the exact name? Thank you for your help.
  • 81 Answers
It is a DVI-D connection. Hope that helps.
Posted on Feb 06, 2009
Would appreciate any advice on connecting cable etc. to connect my Compter and TV to display video/film downloads.s
The easiest connection is converting to VGA and using a standard headphone port-to-audio in. Your video out from the laptop varies by model, which isn't included here.
It will most likely be mini-VGA or mini-DVI
Nov 04, 2012 | Computers & Internet
Tip
Connect you HDTV to your Mac.
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV Port For best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection. If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference. Mac Pro, MacBook Pro, Mac Mini Mac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports. If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac. If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine. iMac, MacBook iMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection. Make the Connection Once you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV. Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac. Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV. Over or Underscan You may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan. You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV. Time to Watch a Movie Once you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
on Feb 22, 2010 | Computers & Internet
How do I connect my iMac 27" i7
You can buy an optional cable that you can plug into the mini-DVI or mini-displayport port at the back of your iMac.see example picture on: http://www.ecoustics.com/electronics/products/new/570842.jpgFirst you need to be sure to know exact if you have a mini-DVI or mini-displayport. The connectors are different and depend on how old your iMac is. Than you can buy the connector that fits your Mac. The you only need to check the connections on your TV. HDMI or DVI will give the best image quality. VGA is older and will result in a lower image quality. Last, you need to buy a cable between the adapter and your TV.
Jun 12, 2012 | Apple iMac Z0GF0005F Desktop
When I connect my unibody macbook pro to my old tv using a vga to tv converter, my computer doesn't even recognize the disyplay.
When you connect your tv to your mac, make sure the cables are plugged into the TV first, and then plug your mac into the computer.
But a vga to tv converted doesn't make much sense. Your connection should be mini-display from your mac, to an adapter to either VGA, DVI, or HDMI depending on your TV connection type.
Dec 31, 2010 | Apple Computers & Internet
Over last 3 years screen has become progressively darker, particularly on the left hand side. It's difficult to see. I was thinking about buying a separate monitor, but not sure what cables I would need to...
Sounds like a backlight problem. Backlights can be replaced but it all depends on the make/model of laptop you have. Connecting an external monitor to your laptop also depends on the type of connection you have on the laptop.
Most (if not all) will have a VGA output which requires a standard 15pin VGA cable. Newer laptops might have DVI or Mini-DVI. Some even have HDMI. So ultimately, the type of cable you need really depends on the type(s) of output your laptop is able to display and the types of inputs your monitor supports.
Dec 03, 2010 | Computers & Internet
Trouble connecting Insignia HDTV 19" to my macbook pro
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Feb 22, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
How to connect my computer to my tv
First off your TV needs a VGA or a DVI connection
there are two types 1. a stand alone TV ( no monitor )
and your regular TV the same VGA or DVI cable used
for your computers monitor is the same cable you'd use
for a TV , it either goes on your video cards VGA or DVI
or on your motherboards VGA or DVI
Jan 28, 2010 | Computers & Internet
How do i connect my compaq pc to tv
Without the model number comptuer, I cannot verify what outputs your comptuer has. Without this, I will provide the various ways a PC can be connected to a TV.
1. Use a VGA to DVI adapter (HD-15 pin to DVI). Use either a standard VGA montor extension cable (cheaper) or a DVI extension cable (more expensive) to make the connection
2. If you computer has a DVI output, use a DVI extension cable only
3. If your computer has HDMI output - use a HDMI to DVI adapter and either a HDMI or DVI extension cable.
In all 3 cases, you will probably need to go to the comptuer's Display Properties and adjust the screen size so it looks OK on your TV (go to the Control Panel - find Display) and adjust the screen resolution to match the format of your TV.
One note - when purchasing DVI cables, understand that there are 3 types - DVI-D (digital), DVI-A (analog) and DVI-I (digital and analog) and that the pin outs are different. Be sure to check your the owners manual of your TV to find which connection it needs.
Here is a good reference for DVI types
http://www.interfacebus.com/Design_Connector_Digital_Visual_Interface_DVI_Bus.html
Dec 02, 2009 | Compaq Computers & Internet
How do I link my IBM t21 to my TV. The sounds works ok from the sound port, and i have an S-video cable to RCA connected, but do not get any picture on my TV
http://www.youtube.com/watch?v=XqjJtdH_EI8
  1. 1 Determine what kind of inputs your TV has. Many sets have the HDMI, DVI or even VGA inputs common on most newer PCs. If you have an older TV with only an analog signal, you will have to get a video card that supports your TV's connection. To determine what kind you need, take a look at the audio/video inputs on the side of your TV. S-video is circular with a bunch of pins; composite video is yellow; and component video is red, green and blue.
  2. Step 2 Find out what kind of video output you have on your computer by looking at your video card. DVI is pretty standard on most computers manufactured in the last four years. Multimedia PCs will have DVI and HDMI. Of course, if you swapped out your video card to accommodate an older TV, your machine will not have either of these connections any longer, but will instead have the one that matches your TV.
  3. Step 3 Purchase cables to run from the TV to the computer. The video cables you need will have the same name as the type of connection on your TV. (For example, if you have S-video, look for an S-video cable.) Note that you will need a stereo-mini-to-RCA cable for the audio as well. All cables are available at most electronics stores. If you shop online, try MonoPrice.com to save some money. (See the link in Resources.)
  4. Step 4 Connect the cables. No matter what type you have, one end will go in the TV and the other into your computer's port (the video cable in the video card and the audio cable in the audio card). It will be fairly obvious what goes where due to the shape and coloring of the ports. Once both cables are hooked up, make sure the picture and audio on the TV both work. If not, check your connections.
Oct 07, 2009 | IBM ThinkPad T21 Notebook
Hitachi 65S500 65" HDTV-Ready Rear Projection Television Logo
116 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
