Question about Remington Powder Actuated To Power Load .22 Brown #R029280
Powder actuated tool wont fire. I think the firing pin is stuck
I have taken it apart and there is powder residue inside I think if I clean it and put it back together it might fix it.??????
  • 2 more comments
  • ranger258 Feb 11, 2009
    Mine doesn't fire, and the load gets crush when I open the loading chamber
  • Anonymous Feb 28, 2009
    wont fire
  • dinnyflier Feb 28, 2009
    hammer model wont fire
  • ranger258 May 11, 2010
    How do I no if there is a firing pin there or not? I have looked inside the chamber, but I don't see any-pin just a round metal circle about the size of the load would seat into would there be some kind of pin protruding out of that round circle? HELP
  • 36 Answers
Is this the one you hit with a hammer? if so check to see if the firing pin is hitting the shell rim at all, if it is sometimes you just have to hit it harder, and make sure your holding the shell in position with down pressure on the handle. if it is the gun model then make sure that the safety lever is is reaching the trip mechanism when you are holding it down making ready to fire.
Posted on Feb 13, 2009
How do I get a stuck empty casing out of the remington powder actuated tool. It's the one that has to be struck with a hammer. The 22 shell fired & nail went into the wood but I can't get the spent casing out of the unit. Anyone know any tricks. Thanks loads Lou
Posted on Jun 09, 2009
Mossberg 500 A old style firing pin; can I replace it with the new factory pin without changing bolts
It'll work but you'll need the spring, too. The old style pin was pushed back out of battery by the locking lug as you pumped the gun. It won't push the new style so you could theoretically have a stuck firing pin fire a shell out of battery. Be safe, just use the firing pin for your bolt....or buy a new bolt off of Ebay. The entire bolt is a direct switch out.
Jul 30, 2016 | Mossberg Optics
Magic Chef wall oven does not turn on after there was a fire in the oven.
I would get an appliance engineer to check/repair it, if a repair is possible.
May 06, 2017 | Ovens
Paslode 900600 Trim nailer not sinking nails
The firing pin can be completed or part of it crooked worn and can have a little burr on its way and stuck in the cylinder somewhere o-rings worn and hardened, have a tilting piston on the firing pin somewhere in the cilinder
Jul 27, 2017 | Air Tools & Compressors
How to fix firing pin from sticking after each shot?
you might have to clean the firing pin, it may be covered with powder residue..
Mar 18, 2012 | RTO Paslode 902000 IM250 Ii Cordless 16...
Can anyone help. ive got a hilti dx450 that won't fire, ive stripped it down and given it a good clean but still no luck getting it to work. could anyone tell me if there should be some sort of firing...
You are correct on the firing pin. Those rim fire caps have to be struck by a firing pin or it won't fire. Pull the head apart and see is the firing pin stuck or missing.
Oct 03, 2017 | Cars & Trucks
I have a model senco sn1v it fires 1 nail then the drive pin fails to retract to the reload position what could be the cause.
The air release behind the pin is stuck. take off the cover on the back and in the center you should see a cap that opens and closes to fire the pin. Carefully tap out the cap ( it is spring loaded ) clean and lub until parts slide easy so spring will close and reassemble
Mar 13, 2010 | Senco & Frame Pro 601 Framing Nailer
How do I take my gun apart? There is a shell casing stuck
What type of Gun is it? Have you ever had it apart to clean it before?
csl USMC
Nov 07, 2009 | Remington Powder Actuated To Power Load...
I have a shell stuck in the gun and can't get it out!
if it is exploded run a rod through the gun when you break it apart. if it is unexploded be careful - it's probably a rim fire cartridge. use plenty of penetrating oil.
Sep 29, 2009 | Remington Powder Actuated To Power Load...
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Remington Powder Actuated To Power Load .22 Brown #R029280 Logo
1,107 people viewed this question
Top Remington Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Remington Measuring Tool and Sensor Expert? Answer questions, earn points and help others
