FixYa.com
Tags:
IBM Print Server
Server with e100 nic
By Charlie - usenet poster
i have IBM server with e100 nic with novell 3.2
on a switch 100
if some 1 is coping from this file server
all the users are hold and no 1 can login
only if the coping is stooped every thing goes to normal
how can i fix it
thanks
avi
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Jimmy NY
Jimmy NY - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In article <
Well, have you tried half duplex, as I've seen some hubs not handle full duplex.
Also, it could just be a bad card ... not completely out of the question.
Allen Harris
NSC Volunteer SysOp
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
OK -- looks like you are current here -- as I noted, just trying to control for variables.
Barry Schnur
Novell Support Connection Volunteer Sysop
Please post replies ONLY via the Newsgroup
Solution #3
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
hi allen
i did try if with full duplex and with auto
the switch hub is an auto select port
avi
Novell File Server Configuration Report For Server: MAIN
Novell File Server Configuration Report Created: Thu, Oct 28, 1999 10:51 am
Novell File Server Configuration Report. [Produced by CONFIG.NLM v1.09]
Novell NetWare v3.12 (250 user) 8/12/93
(C) Copyright 1983-1993 Novell Inc. All Rights Reserved.
Server name: MAIN
OS Version: v3.12
OS revision number: 0
Server Up Time(D:H:M:Sec).: 2:15:57:47
Serial number: 77306578
Licensed Connections: 250
Internal Net. Addr: 01234567h
Security Restriction Level: 1
SFT Level: 2
Engine Type: NATIVE
TTS Level: 1
Total Server memory: 511.61 MB or 536465408 Bytes
Processor speed rating: 32875
Top of Patch List 59 Patches Loaded.
ADROUTFX.NLM v1.01 Apr. 10, 1995 312 Check for invalid route entries (950410)
AUDITFIX.NLM v1.00 Apr. 17, 1995 312 patch to Round up # of blocks reported by accounting (950417)
BCKTTSFX.NLM v1.02 Jul. 15, 1994 312 patch to fix server hang on large backout of TTS files.(940715)
BHANDFIX.NLM v1.00 Oct. 18, 1994 312 patch BHANDFIX.NLM (941018)
CON0PBFX.NLM v1.01 Apr. 9, 1996 312 patch to fix abend from PacketBurst using conneciton 0 (960409)
CTRSTKFX.NLM v1.00 Dec. 21, 1994 312 patch to fix server hang in stack filter code.(941221)
DAICCFIX.NLM v1.01 Dec. 18, 1995 312 patch to fix ccode for DeviceIOCTL (951218).
DESLOTFX.NLM v1.00 Apr. 10, 1995 312 patch to fix dealloc / alloc slot code.(950410)
DFILTRFX.NLM v1.00 Feb. 27, 1995 NetWare 3.12 patch for loop in MM_Detach_Filter
DHANDFX.NLM v1.01 Dec. 23, 1994 312 patch to preserve directory handles.(941223)
DIRSPCFX.NLM v1.01 Apr. 26, 1994 312 patch to correctly limit vol space for the DET and Extended DET.(940426)
EAACCFIX.NLM v1.01 Apr. 26, 1994 312 patch to fix Extended Attributes access with RF rights.(940426)
EAALLCFX.NLM v1.00 Apr. 4, 1995 312 patch to fix server Abends / hangs during EA allocation.(950404)
EADATFIX.NLM v1.01 Apr. 26, 1994 312 patch to fix invalid data Extended Attribute Errors.(940426)
EAFLTFIX.NLM v1.00 Dec. 21, 1994 312 patch to filter corrupt EA requests.(941221)
EAREPLFX.NLM v1.01 Apr. 26, 1994 312 patch to fix invalid reply length with Extended Attributes.(940426)
EASUBFIX.NLM v1.00 Jul. 26, 1994 312 patch to fix EA directory access with RF rights.(940726)
EAWRITFX.NLM v1.00 Dec. 2, 1997 312 patch to allow EA copy without modify rights.(971202)
EAWRNFX.NLM v1.04 Nov. 26, 1997 312 patch to add almost out of EA space alert (971126)
ELEVFIX.NLM v1.01 Apr. 26, 1994 312 patch to fix elevator corruption.(940426)
EVNTRPFX.NLM v1.00 Jan. 18, 1996 312 patch to fix NCP Extensions.(960118)
GETNSPFX.NLM v1.00 Feb. 13, 1996 312 patch to fix original name space code.(960213)
GLOCKFIX.NLM v1.01 Feb. 12, 1996 312 patch for Get Locks problem (960212)
GNSFIX.NLM v1.01 Mar. 28, 1994 312 patch to allow reconnection when connection table is full.(940328)
GTALLYFX.NLM v1.00 Oct. 18, 1994 312 patch to fix abend condition in GetTally (941018)
HFFIX.NLM v1.00 May. 26, 1994 312 patch to stop OS hang if Hotfix abort occurs.(940526)
IOHANDFX.NLM v1.00 May. 26, 1994 312 patch to fix Media Manager release of IO handles.(940526)
IPXRCVFX.NLM v1.01 Apr. 26, 1994 312 patch to fix invalid fragment count during IPX receive.(940426)
LSLUNBFX.NLM v1.00 Dec. 21, 1994 312 patch to fix internal unload of MLIDs.(941221)
LSTECBFX.NLM v1.01 Jul. 26, 1994 312 patch to fix loss of ECBs with packet signing.(940726)
MACNMFX.NLM v1.00 Aug. 12, 1996 312 patch macnmfx.NLM (960812)
MMACCFIX.NLM v1.01 Apr. 26, 1994 312 patch to fix disk I/O halt on file read aheads.(940426)
MMHANDFX.NLM v1.00 Feb. 13, 1996 312 patch to fix handicapped reads.(960213)
MMMIRRFX.NLM v1.03 Mar. 19, 1996 312 patch to fix incorrect alloc of bitmap. (960319)
NCPCHKFX.NLM v1.00 Apr. 5, 1995 312 patch NCPChkFx.NLM Check for invalid NCPs (950405).
NCPXTNFX.NLM v1.00 Nov. 21, 1995 312 patch to fix NCP Extensions.(951121)
PBWANFIX.NLM v1.02 Apr. 19, 1994 312 patch to fix Packet Burst packet storms on WANs.(940419)
READQFIX.NLM v1.00 Aug. 10, 1994 312 patch for full queues (940810)
REALMFIX.NLM v1.02 Feb. 12, 1996 312 patch for IOCTL aborts during real mode execution (960212).
REGOBJFX.NLM v1.00 May. 26, 1994 312 patch to set info valid bit in object status.(940526)
RENDIRFX.NLM v1.01 Sep. 5, 1995 312 patch to fix RenDir bug (950905)
RKIELFIX.NLM v1.00 May. 4, 1994 312 patch to fix Richard Kiel memorial abend # 27 message.(940504)
RTCHGFIX.NLM v1.02 Dec. 18, 1995 312 patch to fix stop signing on route change problem (951218).
SAPFX.NLM v1.01 Dec. 18, 1995 Fixes lost SAPs with servers of same network address (951218)
SEARCHFX.NLM v1.00 Apr. 28, 1995 312 patch to fix SEARCH DELETE console command bug (950428)
SHRRAMFX.NLM v1.01 Jan. 8, 1996 312 patch to increase amount of shared RAM. (960108)
SIGLOGFX.NLM v1.00 Dec. 21, 1994 312 patch to fix packet signing failure on login.(941221)
SPXDDFIX.NLM v3.00 Jan. 23, 1996 Patch for SPX data delivery during termination and connection request retrys
SPXFIX2.NLM v3.00 Jan. 23, 1996 Patch to handle SPX terminate acks on non-existent sessions.
SPXNSFIX.NLM v1.00 Jan. 23, 1996 Patch for SPX handling of Terminate Acks on Non-existent sessions.
STDIRHFX.NLM v1.00 Sep. 23, 1996 312 patch to fix StartDirectoryHandles.(960923)
SYNCMFIX.NLM v1.01 Apr. 26, 1994 312 patch to fix mirrored drive synchronization.(940426)
TRBUFFIX.NLM v1.00 May. 26, 1994 312 patch to fix data corruption caused by transfer buffers.(940526)
UNLDIRFX.NLM v1.02 Dec. 21, 1994 312 patch to fix Abend:UnLockDirectoryEntry called with entry that was already unlocked.(941221)
UNLOADFX.NLM v1.01 Dec. 18, 1995 312 Patch to Fix GPPE when Unloading NLM'S (951218)
VOLMTFIX.NLM v1.00 Aug. 10, 1995 312 patch to fix vol mount problem with CD Rom (950810)
WRLENFIX.NLM v1.00 Dec. 21, 1994 312 patch to fix Abend caused by illegal write offset.(941221)
WSMSGFIX.NLM v1.01 Dec. 18, 1995 312 patch to fix double byte broadcasts for NetWare J (951218).
ZEROBFIX.NLM v1.01 Jul. 18, 1996 312 patch to fix access to zero byte files on CDROM (960718)
End of Patch List 59 Patches Loaded.
Top of Modules List 36 Modules Loaded.
A3112.NLM v4.16a Nov. 24, 1997 OS Support For NetWare 4.x NLMs
(c) Copyright 1993-1997, Novell, Inc. All rights reserved.
AFTER311.NLM v4.12 Nov. 24, 1997 Locale Support For NetWare 4.x NLMs
ALBUILD.NLM v4.01a Nov. 21, 1997 Alert Builder NW (Build 120.000 11/21/97)
(C) Copyright 1993-1997 Computer Associates. All Rights Reserved.
AVENGINE.NLM v22.12 Aug. 22, 1998 Anti-Virus Scanning Engine Library v22.12
(C) Copyright 1995-1998 Iris Software. All Rights Reserved.
BSPXCOM.NLM v7.00 Dec. 22, 1998 BSPXCOM.NLM v7.0.400, Build 112
BTRIEVE.NLM v7.00 Jan. 8, 1999 BTRIEVE.NLM v7.0.500
CLIB.NLM v3.12m May. 14, 1999 NetWare C NLM Runtime Library v3.12m
Copyright (C) 1989-1999, Novell, Inc. All rights reserved.
Patent Pending--Novell, Inc.
CONFIG.NLM v1.09 Nov. 24, 1997 NetWare Scheduler
(C) Copyright 1997, Novell, Inc. All rights reserved.
CPUCHECK.NLM v1.00 Oct. 9, 1997 NetWare Processor Checking Utility
ETHERTSM.NLM v3.80 Mar. 1, 1999 Novell Ethernet Topology Specific Module
(C) Copyright 1990 - 1999, by Novell, Inc. All rights reserved.
HASPSERV.NLM v6.00 Feb. 23, 1997 Aladdin NetHASP License Manager NLM
Copyright (c) 1997 Aladdin Knowledge Systems.
ICORE.NLM v1.00 Jan. 29, 1998 InocuLAN Icore NW (Build 122.000 01/23/98)
INOCUCMD.NLM v4.00e May. 22, 1998 InocuLAN Cmd NW (Build 126.000 05/22/98)
(c) Copyright 1993-97 Computer Associates. All Rights Reserved
IPSRAID.HAM v4.00a Jun. 21, 1999 NetWare 3.2/4.11/5.0 NWPA IBM ServeRAID Adapter HAM.
Copyright IBM Corporation 1995-1999.
MATHLIB.NLM v3.12j Dec. 20, 1995 NetWare C NLM Runtime Math Library (387 Support) v3.12j
Copyright (C) 1989-1995, Novell, Inc. All rights reserved.
MONITOR.NLM v1.76 Oct. 7, 1993 NetWare 386 Console Monitor
Copyright 1993 Novell, Inc. All rights reserved.
MSM31X.NLM v3.95 May. 12, 1999 Novell Generic Media Support Module
Copyright (c) 1990 - 1999, by Novell, Inc. All rights reserved.
NBI.NLM v2.25 Oct. 20, 1998 NetWare Bus Interface
Copyright 1995-1998 Novell, Inc. All rights reserved.
NPAPATCH.NLM v1.03 Aug. 12, 1996 NetWare 3.12 patch for loading NPA modules
Copyright 1996 Novell, Inc. All rights reserved.
NUT.NLM v1.13 Dec. 20, 1990 NetWare 386 Utility User Interface
Copyright 1990 Novell, Inc. All rights reserved.
NWAIF103.NLM v1.00 Jan. 23, 1998 nwaif103.nlm v1.00, Build 76
NWBSRVCM.NLM v7.00 Dec. 22, 1998 NWBSRVCM.NLM v7.0.400, Build 112
NWMKDE.NLM v7.00 Jan. 8, 1999 NWMKDE.NLM v7.0.500
NWPA.NLM v2.34 Oct. 7, 1998 NetWare 3.12/4.x NetWare Peripheral Architecture NLM : NBI Aware.
Copyright 1991-1998, Novell, Inc. All rights reserved.
NWSNUT.NLM v4.11 Oct. 17, 1994 NetWare NLM Utility User Interface
Copyright 1994 Novell, Inc. All rights reserved.
NWUCMGR.NLM v1.05 Sep. 30, 1998 NWUCMGR.NLM v1.5 Build 112
OS2.NAM v3.12c Jul. 29, 1996 Netware 386 HPFS Name Space Support
PCNTNW.LAN v3.30 May. 29, 1997 AMD PCNTNW
(C) Copyright
read more »
Solution #4
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
Server name: MAIN
OS Version: v3.12
SFT Level: 2
Engine Type: NATIVE
TTS Level: 1
(C) Copyright
read more »
Solution #5
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
It might be a bad print queue. I remember reading an article on novell web
site about this problem.
It could be three things, one of which is a print queue.
Do a search for copy + file + login
Greg
Can you Help with these Print Servers problems?
Print Servers
Axis print server losing...
I am troubleshooting an axis... Answer This...
Print Servers
Assembly Instructions
Looking for assembly... Answer This...
Print Servers
Internal Zebra Print Server
I want to connect Zebra Printer... Answer This...
Print Servers
sharp copier
light blink 1 then L will not... Answer This...
IBM (4162) Print Server
Telex 1187 printer setup...
We have a Telex 1187 printer... Answer This...
Repair Service
Find Print Server Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
