I've got a problem with this machine of mine- A flip-chip Celeron 533A (first FC-PGA Celeron) on a GA-6BX7 with F4 bios (i440BX).
The mainboard has a jumper called the "Magic Booster" that is supposed to increase the Core Voltage of the processor (which is autodetected) by 10%. Now, I am a lucky bugger with aforementioned Celeron, because it will actually hit the 800MHz AND operate reliably with a mere 10% increase in voltage- which would be .15V- so from 1.5V (stock voltage) it is increased to 1.65V. I have tested it on two other mainboards at 800MHz with 1.65V (Abit and Asus models) and it is rock solid, with standard cooling.
The problem is the GA-6BX7 not providing the 1.65V, but only 1.6V. I take a look at the core voltage in the bios, it is reported as being 1.6V. As a result the processor "seems" to operate reliably, occasionally crashing in certain situations.
Why would the GA-6BX7 do that? Does anyone have any ideas?
Magic booster is just one of several names the Taiwan have used for the same thing, it is the same as the Voodoo setting, and VCC3 for that matter. Mike Mullen CST Gigabyte UK ...
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on "Magic Booster" [GA-6BX7]:
Solution #2
posted on Aug 01, 2007
LiZzIe - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
I am little confused about this. The GA-BX2000+ has a Magic Booster jumper JP3 and Voodoo jumpers JP20 and JP21. Is the Magic Booster labeled correctely on this motherboard? I thought the Voodoo jumper was intended for AGP cards with a high current demands.
On the GA-BX7+, the Magic Booster jumper JP3 has five different settings. They are as follows:
3-4 close = 10% 5-6 close = 20% 7-8 close = 30% 9-10 close = 40% 11-12 close = 50%
The other boards (BX2000+ and BX7) only have one setting which is 10%.
Now lets go back to the GA-BX7 motherboard. You are saying that "Magic Booster" label in the manual is wrong and it should really be labeled as a "Voodoo" jumper. Is this also labeled incorrectly for other motherboards?
Solution #3
Janice - usenet poster
Thank you for responding Well, that would certainly explain why it wouldn't work as I expected it to... The manual gave me the impression this particular jumper was exactly for this purpose. The strange thing is the magic booster does actually increase the Vcore from 1.5V to 1.6V.
The mainboard itself is a great product though.
