Question about Whirlpool Ultimate Care II GSW9650LW Top Load Washer
Leaks water fron clear hose
One end of the clear hose is disconnected and I wanted to know where to attach
  • 135 Answers
Upper end goes to the water level control, lower hooks into the right side of the tub, between the tub and cabinet. Hope this helps!
Posted on Feb 05, 2009
Fuel line problem at fuel filter conector, 1994 Buick Century
I know the feeling well when this happens. I to did the same as you and also did the clamp, but found the best way was to yous a crimp tool for fuel lines and its not come off since its like the tool to put brake lines on to the calipers and then you put the rubber hose onto it and using a fuel line clip to hold the rubber in place. has lasted the last 5 years now with no problems.
Jan 14, 2014 | Buick Century Cars & Trucks
Need help, I have a 2001 Chevy cavalier 2.2 L..It hs been over heating, can't find the leak. Put water in it and it is bone dry real fast.We took out the thermostat and let the car idle for a while,...
Dear, check water leakage from the heater's radiator. For this, disconnect water circulation to the car cabin heater.
There are two water carrying hoses for the heater, one is to carry water to the heater and the other one is to carry it back to engine. One end of these two hoses is connected to the engine side and the other end of these hoses is connected to the heater side.
You have to disconnect any first hose's end from the heater's side and second hose's end from the engine's side.
Now connect the hose end, which you had disconnected from the heater
Aug 31, 2011 | 2001 Chevrolet Cavalier
There's a clear hose near where the water tray comes out. I think it is disconnect from somewhere, because now the water is not going into the tray but leaking everywhere. Where does that clear...
The clear hose attaches to the drain hole for draining the bucket into a quart sized, low sided container. Or into a floor drain, if you have one available. Th clip of the end is for shutting the hose off temporarily when draining it.
Jul 25, 2011 | Danby DPAC8099 Air Conditioner
2007 Chevy Suburban Front washer sprays and works fine, but when you activate the rear washer, you can hear the motor run but no liquid comes out. I have parled on cement and activated it and I see no...
Best way to check that is to first disconnect the hose from the washer motor and make sure there is good fluid flow from it when it's activated. If there is, re-connect the hose and remove it at the end that attaches to the rear squirter nozzle and do it again. If fluid comes out, clean out the nozzle with a single strand of wire from any piece of old wiring you have lying around (except household lamp cord as the strands are too thin). If no fluid comes from the hose, disconnect the end at the pump and attach it to a siphon hose coming from a gallon of plain water and wait till you see it leaking. If you still cannot find it likely the hose is not leaking but has become plugged or pinched. blowing air through it (at low pressure) will often fix that.Otherwise, you will need to remove the hose and physically inspect it. Obviously, that's the last thing you really want to do though (no fun). Over half I've done turn out to be a plugged nozzle.
Jun 02, 2011 | Chevrolet Suburban 1500 Cars & Trucks
Elba WA50T54W1 water just overflowing not cutting of when full
water level pressure switch tube is clogged with lint or bladder in pressure switch is bad. disconnect power to washer open timer console look for a clear rubber hose disconnect fron switch and blow in tube a couple times reconnect tube and put unit on drain and spin for a second then retrying unit for water level fill put washer on small load water size and test if it continues to fill replace pressure switch...
Jan 23, 2011 | Washing Machines
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Isuzu rodeo leaking coolant from engine
with my experiance on these engines it's usually the upper outlet hoses running from the heads into a t then into the upper radiator hose they are pain to replace but 3 out of 3 of my v6 isuzu's have had the same problem you'll have to pull off the theromstat and the coil pack the hoses are very small and run from the end of the heads one on each into a t then into the radiator hose just under the housing
Apr 27, 2009 | Isuzu Rodeo Cars & Trucks
Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Water fills to overflowing without stop
replace the hose ..connects to tank other end goes under console to water level switch so no level control
Nov 16, 2008 | Admiral AW22 Top Load Washer
Whirlpool Ultimate Care II GSW9650LW Top Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
