Question about Brother HL 5250DN Laser Printer
My broher 5250DN keeps showing toner needed, but i've replaced it
Prinetr worked fine until it was time to replace the toner again (i've done it many times, so I know how to pull out the tabs etc). Sfter I tried replacing it with brand-new, brother, factory made toners, it still won't print. Rather, the toner light stays lit, as if the toner is out or missing. any sugges's?
  • Thomas F. Schneider May 11, 2010
    What ever switch or item that causes the printer to know that the toner is out is not goihg back into the full/filled position.
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Possible that there is any dry ink inside the system?
  • 3 Answers
I just had the same problem. We have several of these in our office, but switching toner cartridges made no difference. Then I saw this site: http://www.oasis-imaging.com/images/pdf/cart_inst/TN580.pdf
I did steps 14-16, which takes 5-10 minutes. I put the toner back in the printer, turned it on, and it works perfectly now. Give that a try!
Posted on Apr 24, 2009
I have a brother 5250dn printer that's on strike right now. At first it wouldn't print indicating a drum problem. We addressed that issue by resetting the drum counter (took out the toner/drum and held...
Try this.... no guarantees but I have seen this work.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jan 19, 2011 | Brother HL 5250DN Laser Printer
Drum light is blinking and not sure how to change it or fix it in Brother HL-5250DN
Hit the purple/blue button on the top of the printer 3 times. This will print a settings report of the printer showing you the toner levels and the drum life.
If you need a new drum purchase one. (I would suggest a new printer at this time but if you like it continue on)
Open the front of the printer and pull out the toner and the drum cartridge. The drum is on the bottom of the toner. Disconnect the drum from the toner and connect the new drum. Replace the toner/drum and you are good to go.
Nov 15, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer TONER LIGHT ON & NO PRIN PAGE
When the toner light is on this means the toner is empty and needs to be replaced before it can print again. Replace the toner and you will be able to print again.
Jun 05, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Brother 5250DN Printer Toner light
Try resetting the toner counter manually;  * Turn off the printer and open the front cover * Press and hold the Go-button down * Turn on the machine while still holding button down, when all three LEDs are lit, release Go-button * Press the Go-button twice, and all three LEDs should be lit again. * Press the Go-button five times (six times if you have the High Yield toner) * Close the front cover and the toner counter should be resetted.
Jun 02, 2009 | Brother HL 5250DN Laser Printer
Cant replace a toner cartridge
It's done via the printers internal menu system:
On your Menu Select button press the arrow down once, then press the right or left arrow until it displays Menu Engine, then press down arrow again, then arrow right or left until it displays Engine Replace Toner (not Engine change toner SZ), then arrow down again, then arrow right/left till it shows the toner color you need to change, then hit the Menu Select button in the middle. The cartridges rotate until the one you selected appears, open the door and voila!
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
The following worked on the 3 of our HL 5250DN printers that stopped printing for no apparent reason with both the status and toner lights on:
After hours of working on one of the printers, virtually taking the entire thing apart and replacing fusers, toners and drums, I accidently stumbled onto this sequence. When I tried it on the other 2 printers, Voila! Took like 1 minute each. It must cause some kind of reset of the toner detection switch.
Apr 17, 2008 | Brother HL 5250DN Laser Printer
MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Mar 10, 2008 | Brother MFC-8460N Laser Printer
Brother HL-5250DN
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Sep 01, 2007 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
387 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
