Question about GE Ovens
Oven door The glass in the oven door is broken THE OUTER GLASS HAS BROKEN AND GE DOES NOT MAKE THEM ANYMORE. THERE MUST BE SOMETHING I CAN REPLACE IT WITH AND STILL BE SAFE.
  • Jim London
    Jim London May 11, 2010
    Hi, Just because Ge doesn't make it anymore doesn't mean there aren't some out there. Give us a model/part number and see if anyone can find you one.
  • 979 Answers
Contact your nearest appliance store. Most have GE parts in stock. This may be more available than you think. I have seen someone take tempered glass and literally glue it with special heat resistant glue and it looked really pretty nice. The edges were beveled and not sharp. This of course is a last resort.
Posted on Feb 06, 2009
Broken outer glass
Please can you help to find a part number for outer door
glass or is any other outer door glass suitable for
AEG MCC3880EM I can fit in? Many thanks
glass , how much it would cost or is any other outer door glass suitable for
Dec 07, 2012 | AEG Ovens
I have broken the outer glass on one of the doors on a thermador SC302TB oven. Is replacing the glass something that a handy homeowner could do?
Yes. replacing the over door glass is no more difficult than removing a few screws, inserting the new glass and reattaching the screws.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232432&diagram_id=194162#d194162
That link will take you to a detailed image of the door as well as where you can order a replacement.
Hope this helps.
Sep 06, 2011 | Thermador SC302T Electric Double Oven
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Broken outer panel of glass on cooker door
I found a replacement for my oven on ebay. Be careful, though, because one seller offered one that was the wrong size.
Apr 01, 2009 | Ovens
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
BROKEN GLASS ON OUTSIDE OVEN DOOR STOVES S5 600MF
You can normally replace the outer door glass independently of any other parts.
Try-----www.espares.co.uk
Plz rate my solution.
Thanks.
Jan 18, 2009 | Stoves Premier 600EMa Electric Single Oven
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
Outer glass needs cleaning
yes. open door slightly to first stop point, pull up on door. the door will come off. there are screws on the bottom of the door and on the side facing the inside of the oven remove these screws to take door apart
Nov 18, 2007 | GE Profile JTP18 Electric Single Oven
Ovens Logo
147 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
