Question about Sony Ericsson W350i Cell Phone
Broken flip how to fix the flip on the phone. i goes on but does not close all the way.
All you need to do is take the flip off and try putting the flip on at a different angle, keep trying it and it'll work eventually, cus the little atachment thing is a square so there arent many ways it can be attached!
Posted on Jun 28, 2009
3 Suggested Answers
cellphoneer
  • 173 Answers
SOURCE: Broken flip
I fix cell phones and you can indeed fix a flex cable broken in half phone, but that phone just may not be worth it.
Posted on May 29, 2008
ashlocked
  • 1140 Answers
SOURCE: my p990i phone the fip
You need to dismantle the back panel and unscrewing 6 screw using a T6 precision screw driver to be able to release the front panel,but be careful cause the keypad flex connector is attach on the board interface and be careful cause touchscreen and LCD is also connected. On the upper panel,remove the keypad panel by inserting a flat screw driver on each side at the bottom of the front panel.if done,remove the adhesive at the back of the keypad interface and you will see the keypad flex connector,if the parts is still ok,gently remove the flex cause it is fitted by a strong adhesive.the you can replace or if not put an adhesive on a broken part.
good luck....
Posted on Jun 20, 2011
If i have the slide opened the screen and image works ok but if i slide to close the keyboard, the screen goes dark with some glitchy images sometimes and then if i open it again and use the direction keys...
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Aug 25, 2010 | Nokia N95 Cellular Phone
My lg vx8700 has only been used for a month and the screen goes blank on it about 7-15 seconds after I flip it open.
The problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
This is a common problem with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I will suggest you replace the flex on the screen of your phone to solve the problem.
If you cannot change the flex yourself, you can take the phone to a local repairer within your vicinity, so that the flex can be fixed or replaced.
Take care.
Jul 08, 2010 | LG VX-8700 Cellular Phone
My screen goes in and out on my lg rumor
Take care.
Jul 19, 2010 | LG RUMOR Cellular Phone
Nokia 61231 screen goes black after turned on
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
Good luck.
Jun 15, 2010 | Nokia 6131 Cellular Phone
Whenever I slide the phone closed and then slide it open the screen goes completely white. How do I fix this?
Take care.
May 21, 2010 | Samsung SGH-J750 Cell Phone
White screen when i open phone
Good luck.
Apr 23, 2010 | LG VX5500 Cell Phone
My screen is white all the time even when i turn it on and off. i keep pressing a button when it goes black to see if it goes norma but its not working. it only stated happening today. how can i make it...
the problem is from the flex that connects your screen to the phone's main board. The flex is weak/worn out.
This problem is very common with flip and slide phones. Its as a result of constant/frequent opening and closing of the slide or flip phone.
First get the phone opened and check if the flex is well fixed. If its well fixed, then you will have to change the flex.
Best regards.
Feb 20, 2010 | Samsung SGH-D900 Cellular Phone
FLIP IS BROKEN. wHEN I OPEN IT THE PHONE GOES WHITE
take the phone and have it fix from a mobile shop
Aug 30, 2008 | Cell Phones
No veiwing screen
Well the screen is rather broken or the switch which turns the sreen on when u flip it open is sticking, this is just on the back at the top. the next hing is that the screen is broken. the thing about people calling in would be the setting, u can not change the setting because u can not see wat u r doing on the phone.
Nov 04, 2006 | Motorola Mobility RAZR V3
Broken flip
Hello, Verizon has to repair your phone for you!!! I had the same exact problem and they said it was a defective part and that they would fix it... Just go into the store and tel them they have to because it is a known default. I just had to get mad. After i did that i got alot more help. Good luck!!!
Jul 11, 2006 | Samsung SCH-a670
Sony Ericsson W350i Cell Phone Logo
249 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
