Back to:
Tags:
Honeywell Humidifier with Hygrometer Humidifier
Humidistat for humidifier
By Brad - usenet poster
I am installing a humidifier on a force hot air system. I decided to
loacat the humidistat in the living area rather than the duct. Since
the humidistat determines relative humidity, it must accurately
measure room temperature. In the return duct in the basement I don't
believe it would read the temperature accurately.
Does anyone know if there is a significant gain in accuracy by
mounting the humidistat in the living area rather than the return
duct? Or should I just take the easy way and mount it in the return
duct.
Thanks.
Alan
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
FixYa! (100)
Cornish
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The humidistat is from Honeywell and it is designed for either duct or
wall mounting. The problem with accuracy is the calibration. There is
a screw in all humidistats that is used for calibrating. I have an
accurate hygrometer so I would know if it was calibrated accuratly.
I also thought of using it to control the central a/c unit. I suspect
controlling humidity would be more energy efficient than just
maintaining a fixed temperature. The house would then be comfortable
at a higher temperture so long as the temperature isn't high into the
80s.
Alan
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Humidistat for humidifier:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Hart
Rating: 0%, 0 votes
So long as it's designed for the job, a humidistat in the living area
will work fine. A humidistat designed for duct mounting may not be set
up to allow convection airflow through it as would be required for a
wall-mount unit. And a wall-mount unit may not be designed to tolerate
the dust of a duct-mount situation.
Probably the duct-mount unit would give a little tighter control, but
the difference wouldn't be great. The things aren't incredibly accurate
to begin with.
Thank You!
Solution #3
Not Rated (0)
Hart
Rating: 0%, 0 votes
I just installed a new Kennmore 15 gal unit on my forced air system.
According to the instructions, the best place was to place the Humidistat on
the cold air supply. At theis point the humidistate could measure the room
temp as well as humidity and adjust accordinly.
Thank You!
Solution #4
Not Rated (0)
lawyer
Rating: 0%, 0 votes
I would imagine that the manufacturer realizes the difference, if any, and
would account for this in its design. So its possible that it reads the
temp and humidity TAKING INTO ACCOUNT its placement in the return.
Thank You!
Can you Help with these Humidifiers problems?
Humidifiers
I am servicing a Carrier humidifier M/N: HUMCCSBP2017A. ...
Humidifiers
Lost instruction manual...please help!
Humidifiers
How do I clean my Kenmore Quiet Comfort humidifier?
Loading problems.
Repair Service
Find Humidifier Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
