Question about Kenmore 24 in. 15932 Built-in Dishwasher
Dishes not getting clean
I have a Kenmore Quietgard 5. In the past month, the dishwasher hasn't been cleaning the dishes well, especially glasses. The glasses come out hazy and spotty and the dishwasher doesn't work as good as it had in the past. Can you help? Thanks
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Www.dishwasherfilter.com has a new product out that filters the water going into your dishwasher. your problem is not the dishwasher but actually the minerals in the water when heated in the dishwasher leave residue and white film. this product is amazing and very affordable. you can get it at www.dishwasherfitler.com.
Posted on Mar 14, 2009
    Scholar:
  • 93 Answers
First is the water getting hot in the unit (if you open it mid cycle you should have a lot of steam comeing out(2)when last did you refill the salt dispensor?(3)when last did you fill the rinse aid dispensor?Check all the above make sure of these (water hot?Dispensors are full?)then at the bottom of the machine inside you will see a filter this normally just pulls out and can be cleaned and replaced,then while you head is in the machine visuall inspect the wash arms and check all the holes in them are open and that none are blocked at all if they are then unclip or unscrew the arm and clean them out and replace then give it a try if all these things are right it should work let me know if all is ok or if you need further assistance.
Posted on Feb 06, 2009
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
The dishwasher is not cleaning well. There is a film left on the dishes and especially the glasses.
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Nov 30, 2010 | Kenmore 24 in. 16039 Built-in Dishwasher
Dirty cups and baby bottles after dishwasher has been run
Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
My dishes come out dirty and glasses are cloundy.
#1 check the upper spinner arm to see if it is clogged with particles if it is, clean the holes outi f they get clogged the arm-sprayer will not clean the upper rack
#2 if it is not clogged got to your local Grc.chain and purchase a bottle of dishwasher cleaner for about 8.00 follow all instructins on bottle make sure water is hot by running hot water tap closest to dishwasher.use it in an empty dishwasher.You will be amazed how clean your dishes will come out after the first wash
Jan 23, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite Dishwasher leaving crud on dishes
yes it is under warranty so call whomever sears i imagine and raise hell you bought it in good faith so tell them to fix it right or replace it with a new one.if Sears they are pretty good re complaints so get on the phone and get it done good luck
Dec 12, 2009 | Kenmore Dishwashers
Dishes are not clean
HI, there are three different reasons why this will occur in this type of unit. inspect these areas carefully.
1. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
2.Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
3. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher. Make sure the temp is proper.
Jul 19, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Dishwasher is not washing dishes.
Make sure your water is at least 120 degrees and change to a dishwasher detergent with a water softener and a rinse aid in it.
Jan 31, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishes aren't getting clean, especially glasses on the top rack
check chopper remove bottom spray arm remove 4 screws take of cover then 2 more screws and the chopper is there.probably broken
Nov 21, 2008 | Kenmore Dishwashers
Kenmore Dishwasher
the problem is hard water. go to www.dishwahserfilter.com and get the difi filtration system.
Nov 12, 2008 | Kenmore Elite 45986 Front Load Washer
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
159 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
