Question about Magic Chef 31001 Gas Kitchen Range
Black soot in my oven
My oven gets black soot all over the inside and ialso get a little on bottom of oven door. is there a simple solution?
    New Friend:
  • 92 Answers
If you are making soot you are making carbon monoxide which can be deadly call someone sooner rather then later
Posted on Feb 06, 2009
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Just had the same problem. It was an electrical short and the repairman said that it could have burned the kitchen wall and been a catastrophy. Get rid of it immediately!
Mar 02, 2013 | Microwave Ovens
Everything in and outside our fridge is getting a black soot on it?
This sounds dangerous, I suggest you hire a pro to look into this.
Nov 21, 2017 | LG LFX25971ST Bottom Freezer French Door...
How do i get inner glass door off ignis akl905 to clean it
Simple . for the ignis AKL 950 OVEN. Takes two minutes.
1/ get a 7mm socket or spanner.
2/ open door flat, no need to take off.
3/ bottom of glass, both left and right are two black plastic brackets , with a 7mm bolt through them. Undo bolt both sides.
4/ remove plastic bracket, just lift out.
5/remove door , clean.
Put back on, refit brackets and tighten bolts.
Job done.
Takes two minutes. Just remember which side of glass faces inside. think both sides same, but could be wrong.
Hope this helps. sid . derby..
Feb 14, 2011 | Whirlpool Ovens
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
Hello,do you know what would cause the following problem in an Electrolux Cooker,MODELNO: DD061, PROD NO: 948522135, SERIAL NO: 42900006. THERE IS AN ODD TASTE OFF THE FOOD WHEN COOKED IN THE MAIN OVEN?
is it a gas range?are you getting soot? you need to look at flame while unit is on, remove oven botton to expose the burner, easy!!!! 2 screws on back inside over and pull bottom up. shut door turn on range and look at flame if it is yelolow and long flames you need air ajustment at burner, inside very bottom door you will see the air shutter, open it a litttle if falmes are yellow and long and test it again.
Feb 01, 2010 | Ovens
How do I take off the glass on my oven door to clean it?
I have a Kenmore oven and all I had to do was remove the screw at each end of the handle (accessed with the door open) and the very front section just opened up - SIMPLE!! Wiped it down put the screws back in. Did it all by myself - just have your cleaning cloth in reach before you start. Can't believe I looked at those drips for years and it was that simple!!!
Mar 21, 2009 | Maytag CWE4800A Electric Single Oven
Propane kitchen-oven ''whoofs''
Propane burns very dirty,I bet the burner and pilot are clogged with soot.In techinical terms the sound your hearing is blowback.If you check the burner/pilot you will likley see black soot,remove them and clean with soap and water.
Mar 16, 2009 | Ovens
Kenmore gas: SMELLS
turn them on see if the flames are orange or blue then reply open the door and look from the side through the little slots in the bottom of the oven to see also is there soot and are you on natural gas or propane your reply will come to my e mail
Nov 09, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Magic Chef 31001 Gas Kitchen Range Logo
1,423 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
