Question about Casio Portable Keyboard Touch Sensitive Keys
Casio PX700 sensors not working
My Casio PX 700 sensors do not seem to be working. They use to be touch-sensitive but now it doesn't matter how hard or soft I hit the key; it's all the same sound/volume. How can I fix this problem? Any suggestions would be much appreciated.
Thanks!
  • tara537
    tara537 Oct 30, 2012
    I should have posted my comment here. I also need assistance. The Function button does not seem to make a difference as the manual button suggests.
Hi. I don't have a 700, but on the other privia's I have seen, there is a function key combo to turn on and off the touch response. Go to casio, and download the manual. You hit "fn" and then one of the lower keys. There are 4 levels of sensitivity on my machine. -Don
Posted on Feb 16, 2009
  • 3 Answers
I have the same issue with my Casio Px-700. One day all of a sudden, there is no dynamic. I did look at the manual. And saw the option to hold down Function then C5 to reset - but it did not help. Any one else know how to actually fix this issue. I see I am not the only one with the problem.-Tara
Posted on Oct 30, 2012
I have a Piano from Casio Named The PX830 BP.I also have a Sustain Pedal Model from Casio named the SP 33.Will connecting the SP 33 into the PX830 BP work?Please tell me if I have the wrong model.
Unfortunately, the SP33 pedal will not work with the PX-830BP. Casio lists that the SP33 will only work with the PX-150BK, PX-150WE, PX-160BK, PX-160GD, PX-350BK, PX-350WE, PX- 360, and PX-560 keyboards.
The PX-830 manual does not list the stand or the pedal unit as separate items if you need to replace them. The pedal unit has 3 pedals like a traditional piano. I wish that I had better news for you.
Feb 04, 2016 | Casio Music
Casio Px-135 - even when I touch the key gently it gives me full volume sound
the contact rubbers might be broken or the rubber itself is wornout because of usage or there is dirt in it.. its lose its touch response, the best easient way is to replace the contact rubber.
Apr 16, 2014 | Casio Music
How to fix loud key on Privia PX-830
I just fixed mine, it was making the loud sounds and had seemed to have lost the sensitivity. Take out all the screws on the outside, then the sides can come off. That gives access to the inside where you can take out a few more screws (easily seen) and open it all up. The keys themselves just snap in, so two small screwdrivers or strong fingernails can pop them back out. Clean the rubber contacts (they look like little sockets) with Q-tips and rubbing alcohol, then replace the keys. If you take out the white keys of an octave first, then the black keys (keeping them in order) it is a lot easier.
Jun 18, 2012 | Casio PX-830 BK Privia
Where is the midi connection on the casio px 700
At the bottom near the power jack.
You may need a Midi-to-USB "cable adapter" to connect to a computer.
Jun 04, 2012 | Casio Px700 Digital Piano
The sustain pedal is broken on my PX-700 and I would like to know if there are any replacement pedals on the market that are compatible?
Getting back to the Casio PX-700 - yes it is possible to use a new £14.30 (EBAY) metal pedal which is more durable than the original.
The original pedal has two internal switches (semi-sustain, full sustain) depending on pedal position.
The replacement single-switch pedal is switcheable (normally open or closed) - for this mod, it should be set to 'normally OPEN'.
There are now 2 choices:
i) Are you just interested in Sustain only?
ii) Do you need the other 2 pedals working (mid/left hand)?
For choice i)
Turn off power. You can now cut the old cable where it enters the pedal assembly & remove the pedal bar (held by 2 large screws).
Discard the pedal bar & old pedals.
Open new pedal base & desolder the screened cable (note the screen connection pad position).
a) Run the black cable wire to the new pedal screen pad & solder in place.
b) Join the grey & brown wires & solder to the other pad.
Insulate the unused (yellow/red) wires.
Replace pedal base - JOB DONE!
For choice ii)
a) Dismantle pedal assembly
b) Without removing any wires, solder the two pedal wires to the existing coloured wires as described above - OK to join grey & brown wires.
Problem. The above pedal is 9" overall, so may be placed sideways, so as not to be too far forward.
OR use a smaller guitar-type footswitch (non-latching, normally open).
Jun 13, 2011 | Casio Portable Keyboard Touch Sensitive...
The keys do not allow the voluem to change (piano to forte)
Read page E13 of your manual about setting "touch"... You probably have inadvertently turned it "off" so there is no velocity variation of loudness.
If you don't have a manual, download it here:
http://support.casio.com/pdf/008/PX700_e.pdf
Jan 03, 2011 | Casio Px700 Digital Piano
I have purchased a CASIO CTK 700 keyboard, but I do not anything about it and how to start learning. I want to learn to play the instrument. Kindly teach me
there are many software applications for your computer available out there my advice is to find one and use it all the time as i learnt when i started playing as with any other instrument the only way you will learn is to practise, practise, practice any keep trying it no matter how many times you fail
Nov 09, 2010 | Casio Portable Keyboard Touch Sensitive...
The volume control on my casio px-120 does not work. I can hear the speakers crackle when I try to adjust the volume but the music stays the same.
ok your volume control has bit/dust in it you need to strip it down as best you can and spray wd-40 into the control this will release all the grit in the control knob (trim pot) and should work fine then..
Jun 18, 2010 | Casio Portable Keyboard Touch Sensitive...
I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Nov 30, 2009 | Casio Music
Casio PX-120 Dead Key
Your on the right track. Check for grease on the contact. Clean the circuit board surface with alcohol and a q-tip and also the rubber/metalized switch.Wipe clean with other end of q-tip. Try the key again.
Aug 13, 2009 | Casio Portable Keyboard Touch Sensitive...
Casio Portable Keyboard Touch Sensitive Keys Logo
611 people viewed this question
Top Casio Computers & Internet Experts
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
